20 Most Recent
Krups Stainless Steel Electric Kettle Electric Kettle Questions & Answers
I just recently bought my
" just recently bought my krups kettle and last week "
TAKE IT BACK AS DEFECTIVE FOR EXCHANGE OR REFUND
Krups Tea Kettle isn't working. I believe the
hello,
the handle has noting to do with the heater what you need to check on is the connection from the power supply if the connection is alright then you will have consider the element it is the heat provider connected to the wire it means that it is weak it need to be replace with a better one the element is in silver colour you can get it in any technical store/shop around you.
thank you
The heating element in Krups stainless kettle has burned out
the element is avilb on the web / look under small appliances / or better yet use your model # and google it . the cost of element and shipping may be more than your pot is worth . you be the judge . i would fix it but / it may not be cost efective .. hope this hepls **** ..
Krups Blender 577 replacement of rubber coupling
Krups Blender 577 - first try it not easy but next time it will be.
Replacing the rubber coubling is extremely difficult with this model.
After almost destroying the air in/outtake grill on the side in pursuit of a good lock of the axe, I tried so hard to use a nose plier to grab the post and unscrew the coupling counter-clockwise but it just didn't fit (it needs to be long and narrow/needle like). So I ended up cutting off rubber on the coupling and also cutting of plastic from the black plastic cover which is just under the rubber coupling. In the end I was able to cut that plastic and remove it so that I could actually take off the whole casing (you need a torx 20 with a hole in it to unsrew the 4 bits at the bottom underneath the rubber stands) with the rubber coupling still attached and detach two power cables so that I had much more space to properly grab the post and then it was very very easy to unscrew it counter-clockwise. But up until then I lost my insanity twice :-).
Now I know how to so the next time will be easier.
