20 Most Recent Oster 5965 Electric Kettle Questions & Answers
The warming button is stuck in the "on" position.
Push down on it toggles it on and off. Push down on it and it will release back up. Hope this helped...
2/1/2022 8:15:59 PM • Oster 5965... • Answered on Feb 01, 2022
A black ant got stuck under see through window
Fill Up Your unit full of Water and Emty it . Do it few time and Garanty your Ant will Go for Ride..Then Invite her for Coffee ...Bye
9/19/2017 1:43:07 PM • Oster 5965... • Answered on Sep 19, 2017
2answers
Oster Electric Kettle 5965 does not light up does
Maybe you have the same problem as this kettle... Will not heat water
7/23/2015 12:25:48 PM • Oster 5965... • Answered on Jul 23, 2015
Lidlock is broken its alittle plastic ******
8/31/2014 11:26:55 AM • Oster 5965... • Answered on Aug 31, 2014
How do i replace thermal fuse on an oster 5965 tea kettle?
This unit is discontinued and I doubt it would be cheaper than buying new and that's IF you can find it, sorry. You might get by with a $10 "Digital Power Timer", though. That will shut your kettle off after whatever amount of minutes and seconds you program it for.
8/31/2014 11:25:27 AM • Oster 5965... • Answered on Aug 31, 2014
Oster water kettle leaking from bottom of unit when pouring?
If you're not just simply missing the opening a little as you're pouring then I'd assume it's cheaper to replace than to repair, sorry. If it's leaking from the side-glass you might get by with filling your kettle just under the lower end of the side-glass.
8/31/2014 11:17:59 AM • Oster 5965... • Answered on Aug 31, 2014
Kettle base got water .keeps blowing....how do i solve problem
For the kettle's black 'charging' base: Unplug this charging base immediately. Let it dry out completely. If you have an air hose, contact cleaner or Electronics Duster (compressed air) to displace the water. If you're kettle stopped working after its fully dry (wait a day to be safe), make sure it's still unplugged and check the contacts in the base center for corrosion (there's the center ground pin and if you push down on it's spring-loaded ring around the ground pin you'll find two more inner/outer circumferential contacts). If you see corrosion try to clean them with a cotton swab (like Q-Tip) and alcohol and retry. For the kettle's stainless steel 'pitcher' base: It's the same as above but you'll need to expose the bottom for best results and to find out where's this water it leaking from. You'll need to remove the 3 Phillips screws and one safety-screw with a "spanner insert bit" on your driver. If you don't have access to one of those and your kettle leaks when filled then I'd bet it's cheaper to replace than to repair, sorry. d4c886f7-1d5f-46e6-a259-8f72ad03ad1a.jpg
8/31/2014 11:12:05 AM • Oster 5965... • Answered on Aug 31, 2014
Unit wont heat
8/31/2014 10:51:47 AM • Oster 5965... • Answered on Aug 31, 2014
The lining of the kettle on the inside bottom is
Stainless Steel doesn't boil away. What you're seeing is the mineral deposits (mostly calcium) left behind from heating the heavy water you're pouring into the kettle. Descale it, pour it out and rinse every month or when it gets bad if you like. These deposits won't hurt you but looks nasty. Another option is to use filtered water instead of tap water. Hope this helps a little...
8/31/2014 10:48:33 AM • Oster 5965... • Answered on Aug 31, 2014
Oster kettle not working
Ultimately, how I ended up fixing my Oster 5965 and Hamilton Beach Cool Touch Electric 40898 kettles that had the same problems as you (Nothing would work; no heat, no buttons would light up) was by taking apart the bottom screws (Be warned, for only one screw I needed a "Spanner Insert Bit"). I jiggled the connectors as I rang them out with my multimeter and everything seemed to work. Leaving the bottom off I retested the kettle and it just worked. I reassembled the parts and made my happy wife a cup of English Tea. 0086d2a8-48ac-40cb-9c0a-d2182dc4b660.jpg
8/31/2014 10:38:34 AM • Oster 5965... • Answered on Aug 31, 2014
The lid is stuck
Have you tried pushing your lid down to make sure catch doesn't hang-up before pushing back on the button and pulling it upward? If that doesn't work it maybe damaged (melted by steam, overuse or gunked up with heavy mineral deposits) but to be honest we don't ever open ours. We fill from the pour spout just fine with the lid always closed. You can pour in your descaler the same way. Hope this helps a little...
8/31/2014 10:36:54 AM • Oster 5965... • Answered on Aug 31, 2014
It won't turn on when I push down the switch. It
Ultimately, how I ended up fixing my Oster 5965 and Hamilton Beach Cool Touch Electric 40898 kettles that had the same problems as you (Nothing would work; no heat, no buttons would light up) was by taking apart the bottom screws (Be warned, for only one screw I needed a "Spanner Insert Bit"). I jiggled the connectors as I rang them out with my multimeter and everything seemed to work. Leaving the bottom off I retested the kettle and it just worked. I reassembled the parts and made my happy wife a cup of English Tea. 06f483e8-b64b-46c6-8965-db6713dd9053.jpg
8/31/2014 10:20:56 AM • Oster 5965... • Answered on Aug 31, 2014
Will not heat water
Ultimately, how I ended up fixing my Oster 5965 and Hamilton Beach Cool Touch Electric 40898 kettles that had the same problems as you (Nothing would work; no heat, no buttons would light up) was by taking apart the bottom screws (Be warned, for only one screw I needed a "Spanner Insert Bit"). I jiggled the connectors as I rang them out with my multimeter and everything seemed to work. Leaving the bottom off I retested the kettle and it just worked. I reassembled the parts and made my happy wife a cup of English Tea. Just one thing though. There's no Numerals that ever lit up on my kettle so not sure what you meant by that, sorry. 82bd47fc-90a5-4e40-93a6-ace72392b75a.jpg
1/24/2014 10:06:32 PM • Oster 5965... • Answered on Jan 24, 2014
0answers
Does not heat
Be the first to answer 12/8/2013 4:57:50 AM • Oster 5965... • Posted on Dec 08, 2013Be the first to answer
Lost the manualm for my
here is your manual
http://www.oster.com/manuals/MANUALS/005965-000-000_43_32757971.PDF
Don't forget to rate this answer.
Thanks!
4/25/2011 6:37:43 PM • Oster 5965... • Answered on Apr 25, 2011
I have lost my instructions on proper use of Oster
http://www.oster.com/manuals/MANUALS/005965-000-000_43_32757971.PDF this should be the correct manual. please rate if this helped you. thanks
3/20/2011 5:06:18 PM • Oster 5965... • Answered on Mar 20, 2011
I have noticed black water deposits at the bottom
mix half white vinegar and water together...then pour this solution in just as you would if you were making coffe....minus the coffe grounds of course... then run it through a cycle and then run clear water through again... and you will be good to go...do this once a month or so to keep it working great...
heatman101
8/29/2010 8:59:41 PM • Oster 5965... • Answered on Aug 29, 2010
My Oster kettle is not working. The switch does not work.
if dont work order one for replacement
3/23/2022 2:52:55 PM • Oster Kitchen... • Answered on Mar 23, 2022
How to set bread pan into Oster 5838 Bread maker securely
Question moved from Cars and Trucks to Oster Breadmaker. The manual lists no funny tricks and just says; Carefully snap the baking pan into the breadmaker. https://www.manualslib.com/manual/402115/Oster-5838-Expressbake-Bread-Maker.html?page=11#manual See if you can work out what clicks? It has to be the bottom of the paddle or something on the side of the pan. Parts are available https://www.google.com/search?q=oster+5838+breadmaker+parts Some companies say parts are obsolete, but this site has them https://www.dontpinchmywallet.com/sunbeam-oster-breadmaker-replacement-parts/ This image shows a spring clip in the base of the paddle. Is yours working? Are you pressing the paddle down once the pan is in the breadmaker? https://www.amazon.ca/Oster-5838-026-Machine-Replacement-Kneading/dp/B0019BKPU4 ..
12/12/2021 7:21:27 PM • Oster Kitchen... • Answered on Dec 12, 2021
Oster 5965 Electric Kettle Logo
Popular Tags
22 questions posted
Top Oster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Narseman
Marvin
Marvin
Are you an Oster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Oster Kitchen Appliances - Others
Most Popular Question
oster electric kettle 5965 not light up
  • Kitchen Appliances - Others
