When turn on the tv its asking for a unlocking code a four digit number
SOURCE: i need codes to unlock sanyo tv with uet 606
Please follow this guide to unlock your tv :
www.ehow.com/how_4488981_unlock-tv.html
Regards, Jay_NBHV765C
SOURCE: Hi there, I have just bought a jumbo tv remote and
Hi Emma,
If the instructions for your remote (or universal remote) do list codes for all of the devices (TV, DVD, CD, VCR, etc.) you wish to control with it, I'm sorry to tell you that it probably isn't supported. There are literally thousands of remote codes for all the different device brands and models, and newer versions every year. It simply isn't possible for the remote manufacturer to know of all the products and codes that are "out there" in the world. You can attempt to try ALL the codes to see if if you can find what is needed, but since it is undocumented, the likelihood of the desired function button (such as "volume up") performing the expected task is minimal.
The exception to the universal remote problem detailed above is what is called a "learning remote". A learning remote requires that the device's remote is aimed at the learning remote and pressing buttons on both remotes allows the learning remote to store or learn the other remote's functions. Other variations of learning remotes are the types that have a database of device remote functions that are sent to the remote via USB cable from a computer connected to the internet. This last type is the quickest and possibly the easiest - but is also the most costly.
You could copy the brands and types of devices you wish to control (Sony TV, Pioneer Blu Ray, Sharp VCR, etc.) and go to a store - or better still - go online and view the manual for different remote control units to determine if they do control these devices. Or, you could simply use the universal remote you have to control all the devices it is capable of controlling - and use the original remote(s) of the other device(s) that the universal can not control.
If this was helpful, please rate it accordingly. Thanks & good luck!
SOURCE: what is the code number to unlock child lock techwood tv model no 32832
please go to www. remotecodelist.com and download for free.
God bless you
Press the
"Menu" button to set the lock code for your JVC TV. A padlock icon
will appear on the menu display.
Press "Zero"
to access the lock code function then use the left and right arrows to select
the four-digit number for your code. Use the up and down arrows to move to the
next area of the display.
Select the up or down
arrow to finish your lock code then use the left or right arrow to save your
lock code settings and exit the menu. You can return to this display if you
forget your four-digit lock code and set another code.
Write your four-digit
lock code down and keep it in a safe, private area.
Select the locked TV
channel you desire to watch or want to unlock. A message will appear on the
display requesting you to enter your lock code to unlock the channel.
Unlock your JVC TV by
entering your lock code on the 10-key pad. The message "Invalid Lock
Code!" will appear on the screen if you enter the wrong lock code.
OR
Select "TV"
from the menu then select "V-Chip" from the drop-down list on the
screen. "Please Input Password" will appear on the screen.
Enter your four-digit
password by selecting numbers on the 10-pad that appears on the V-Chip menu
display or your remote control. Create a new password if you forget it by
unplugging your TV power cord from the outlet then reconnect the power cord.
This procedure resets your password to "0000." Enter four numbers for
your new password using the keypad on the screen or your remote and select the
arrow to advance to the next number. Press "OK" on your remote or
select "OK" on the screen to set your new password.
Unlock a TV rating or TV
channel by selecting "MPAA" or "TVPG" from the V-Chip menu.
Use the up or down arrows to select the locked rating then select
"OK" on the display or press the "OK" button on your remote
control to unlock it. The MPAA represents the U.S. Motion Picture Association
of America rating system, such as "NC-17," meaning not intended for
viewers 17 years or younger.
Press the
Press "Zero"
Unlock your JVC TV by entering your lock code on the 10-key pad. The message "Invalid Lock Code!" will appear on the screen if you enter the wrong lock code.
Press the
Press "Zero"
need an unlocking code for a sankey television
