Apple 661-5868 Genuine Original Macbook Pro 13 Lcd Display Assembly A1278 Logo
mario jurado Posted on Mar 22, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Led display assembly cables do not match my mac
Macbook pro display assembly has cables that are different than mine
hamster47
Level 3:
  • Apple Master 739 Answers
  • Posted on Mar 23, 2013
hamster47
Apple Master
Level 3:
Answers
739
Questions
0
Helped
211141
Points
2037
Hi Mario,
Are the part numbers the same? If they are, take photographs showing that and the differences between the cables and send the unit back to where-ever it came from with the photos.
2answers
How do you replace the display cable on a macbook pro?
NOT a solution -
Are you certain the problem is with the display cable, not with the screen itself? Let's make certain of the etiology before we take it apart.
Good Luck!
How do you change the display cable on a macbook pro?
To replace the LVDS cable on a MacBook Pro Unibody, you need to remove the screen assembly and then remove the display glass. (Which normally breaks during removal as it is glued in place).
I recommend taking it to a repairer who is experienced in this procedure as it is easy to damage other parts when doing this.
Locked
Resetting the PRAM may do the trick:
You reset the PRAM by rebooting a Mac and then immediately hold down the Command+Option+P+R keys, you will then hear the Mac reboot sound again, signifying your PRAM has been reset. You must hit the key combination before the grey screen appears otherwise it won't work.
you've tried rebooting, you've reset the PRAM, you've done it all, but your Mac is still behaving strangely. What next? In certain circumstances, resetting your Mac's System Management Controller (SMC) can be a solution. This is sometimes necessary to restore normal lower level system functionality to your Mac.
Here's how to reset the SMC on any type of Mac (and any version of OS X) and the type of problems that it may resolve.
When & Why Reset SMC on a Mac? Some Common Hardware Reasons
Typically it's power and hardware related issues that can be helped or resolved by resetting a Mac SMC, particularly if you're having these types of problems:
* Issues with your Mac's cooling fans and fan management: fans run constantly at high speed, fans run high despite low CPU usage and adequate ventilation, fans not working at all, etc
* Power management and battery problems: Mac isn't turning on, sleep isn't working, random shutdowns and reboots, battery isn't charging, Mac won't wake from sleep etc
* Light problems and improper lighting management: battery indicator lights aren't working, display backlighting isn't adjusting to ambient light changes, keyboard backlights not working, etc
* Video and external displays not working: display brightness functionality not working properly, target video mode isn't working properly, external display isn't working, etc
* General performance and functionality problems: abnormally sluggish behavior despite no CPU or disk usage, external ports not working, airport & bluetooth aren't showing up, external devices are not being found, etc
So now that you've concluded you need to reset your SMC (Note that the SMC is on Intel Mac's only), here's how to do it on MacBook's, MacBook Pro's, iMac's, Mac Mini's, and Mac Pro's. Notice that the reset instructions are different for MacBook and MacBook Pro's if you have an internal or detachable battery.
Reset SMC of a MacBook Air, MacBook Pro Retina, or MacBook Pro's with an internal non-removable battery
This is how to reset SMC on most modern Mac laptops:
Shutdown your MacBook Air / MacBook Pro
Connect the power adapter to your Mac
On the MacBook/Pro's keyboard, hold down the Shift+Control+Option keys and the Power button at the same time
Release all keys and the power button at the same time
Boot your Mac as usual
Here's the key sequence to hold down:
Reset the SMC of a MacBook Air or Retina MacBook Pro
Do keep in mind that by resetting the SMC you will lose power specific settings, like the time it takes to sleep a Mac and other customizations to power settings. No big deal, but if you have made many changes to your hardware behavior you will want to adjust stuff like sleep behavior again.
Reset SMC of an iMac, Mac Pro, Mac Mini
Resetting SMC is different for non-portable Macs:
Shut down your Mac
Disconnect the power cord
Press and hold the Mac's power button for 5 seconds
Release the button
Reattach the power cables and boot the Mac as usual
Reset the SMC of a MacBook or MacBook Pro's with detachable batteries
mac reset the smc Older MacBook laptops with a removable battery can reset SMC with the following approach:
Shutdown the MacBook/Pro and remove the battery
Disconnect the power adapter, hold the Power Key for 10 seconds
Release the power key and reconnect your battery and power adapter
Turn your Mac on
Let boot as usual
Hopefully that will clear up your problems, if not it might be worth a visit to the Apple Store or a certified repair center.
Happy New Year,
Kerry
Restart appears on start up
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
Macbook pro dark screen
Close the lid, attach an external monitor, reopen lid.
Your display should now show on that monitr. If it is, your display on the MacBook Pro may be bad. I would try resetting the PRAM and the SMC before going to an Apple store. The SMC controls the MacBook's power founcts (see below)
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
Cable assembly for new macbook pro display does not match the old one, is there an adapter i can use
Try eBay - first look up what display socket you have and know what you are going into and then hit the ebay search.
Apple change their sockets and you'll have to check which you have.
1helpful
Macbook pro hdmi cord not transferring audio
Verify that you have your sound settings correct. Go to your System Preferences and then to the Sound section.Choose the Output tab and select the Digital Output,also the name of your display may show up please select that.Internal speakers must not be selected. let us know if this addresses your issue. For additional info please view this guide: http://www.kanexlive.com/forums/showthread.php/180-No-Audio
Keyboard Backlit not coming on at all
Set your backlighting in
Apple menu
System Preferences
Keyboard.
otherwise try:
Resetting the SMC on any type of Mac (and any version of OS X) and the type of problems that it may resolve.
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
My apple macbook air shows a question mark when i turn it on
Shut down your Mac
Release the button
Turn your Mac on
Let boot as usual
Happy New Year,
Kerry
1helpful
Macbook recognizes dell projector, but not vice versa
Your Macbook should automaticaly find the best resolution, if everything was OK. Is there any HDMI input on the dell projector? What projector is it? Is there is an HDMI input, you can use a HDMI to mini DVI cable: better picture and sound than VGA, and will probably solve your problem
Top Apple Computers & Internet Experts
Paul Carew
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
