Gardner Bender #GSW-SK Door Switch Logo
A
Anonymous Posted on Mar 18, 2013
SPST Kit Installation diagram - Gardner Bender #GSW-SK Door Switch
WIRING DIAGRAM hu-650
Here are diagrams for hu-650. If they do not fit your needs, then you can call your local library to see if they have a book on your Make and Model.
WIRING DIAGRAM hu 650 RADIO INSTALLATION Google Search
Thank you for contacting Fixya. Does this help? Let us know.
Ponder/Meditate/Pray for Peace.
Mary Oliveau { hugs }
Club car brake light not working
2008 precedenmt golf cart dash light keep coming off an on
Need wiring diagram to install TL21 24 hour time switch (Intermatic)
TL21 is aka WH21 timer rated 23 amps SPST.
Copy following links to identify timer, and replacement parts, and see wiring illustration:
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-WH21-timer.html
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#wh
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Is it possible to convert the texas ranger tr-396fc from cb to 10 meter amateur band?
Note - You must have an Armature License to legally perform this conversion.
1. Remove bottom cover from radio. 2. On the main PCB, locate J33. (See diagram above) 3. Locate wires on pins marked "P5" (yellow) & "P6" (grey). 4. Cut wire on "P5" (yellow) and install a SPST switch in line. 5. Cut wire on "P6" (grey) and install a SPST switch in line. NOTE: By using two of the function switches available on the radio will eliminate the need for two new switches to be installed and mounted.
My SPST switch kit came apart during installation. Do you have a diagram that can show me how to properly put it back together?
If it came apart your best bet would be to purchase a new one. These switches take a lot of pressure on them as the door is constantly being opened and closed. If you did get it back together I do not think it would last long.
I have a paragon timer model 4004-20 and do not have a wiring digram for it . can you help
http://waterheatertimer.org/Paragon-timers-and-manuals.html
I don't find the Paragon 4004-20 listed in manual.
4004-71 is shown, and uses wiring diagram 3
4004-71B, M, S use wiring diagram 4
4004-06 uses wiring diagram 7
Your timer sounds like a 240V DPST
http://waterheatertimer.org/pdf/Paragon-4000-24hr-7000-7day.pdf
Manual shows wiring diagrams, depending on how many screw terminals and loads you have, and voltage of clock motor and voltage of load.
Need diagram for SPST lighted rocker sw--110V
Spst stands for single pole single throw so you are only switching one wire,simply cut the wire in two and put the switch between the two ends.
Galaxy DX 959
Top Gardner Bender Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Gardner Bender Electrical Supply Expert? Answer questions, earn points and help others
