I need the insignia remote control code.
there are several and here they are 1181,1180,1175,1171,0103,0189,0217,0135,0133,0116,0167,1148,0456,0029,0905,1406,1407,1408
try each one seperate
press and hold the setup button until the red light stays on then if it is a universal remote press the desired mode button (example t.v.) the light should now blink and then stay on enter a 4digit code .
note:if the code is valid the light will turn off if the code is invalid then the light will flash.
now try it with your device on by pressing the channel up and down button.
note: if the remote does not control all the functions try another code.
If none of the the codes work try following these steps:
1.manually turn on the t.v.
2.press and hold the setup button.
3. press and release the tv button the light will blink once and then stay on.
4.press the channel button repeatedly up to 300 times until the device changes channels. the light will blink and then stay lit.
5. press and release the mute button to store the code the light will go off.
i just put a new board in it
