20 Most Recent Insignia NS-LCD42HD-09 42 in. HD-Ready LCD TV Questions & Answers
There are these dark or cloudy bars or thick lines
Try replacing the tcon board
2/14/2018 2:37:20 PM • Insignia... • Answered on Feb 14, 2018
Insignia NS-LCD42HD 2+ years old
The TV is very low Grade considered a cheap china knockoff and the panel has gone bad as expected you need t replace the TV and next time steer clear of the non brand products (aka walmart)
2/12/2018 7:09:08 AM • Insignia... • Answered on Feb 12, 2018
2answers
After my 37" vizio is on for a while the screen will go black while the sound stays fine. a restart brings the picture back but in time it will happen again. It seems to be heat related. Does it being
Air holes at bottom and in top of armoir? Try it with back off and doors open. If it works you need the air holes.
11/20/2017 2:37:05 AM • Insignia... • Answered on Nov 20, 2017
Insigna ns37d20sna14
Common problem is this series is the power board fails. Unfortunately it often takes the main board as well.
8/31/2016 10:34:54 PM • Insignia... • Answered on Aug 31, 2016
I have sound but no picture. What can I do to fix it?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
5/18/2016 2:43:14 AM • Insignia... • Answered on May 18, 2016
The picture is blurred and
Good day!!! That problem is usually cauase of bad t-con board please try replace it to end this problem.. Thanks for using fixya..
9/17/2015 7:42:32 PM • Insignia... • Answered on Sep 17, 2015
When turned on it says no input, and no buttons work. when it is turned off it flashes red 14 times and then goes solid.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ Blinking codes details to many popular brand TVs are given. Surf the site with patience.
5/27/2015 7:54:01 AM • Insignia... • Answered on May 27, 2015
2answers
Tv says run channel scan, how do you do this while using a Direct Tv remote?
Use the insignia remote.
2/26/2015 12:53:42 AM • Insignia... • Answered on Feb 26, 2015
How do you remove the pop-up insignia banner at the bottom of TV
Go to menu
Choose settings
Reset setting to factory
Choose retail banner
Set to off
10/22/2014 5:29:10 PM • Insignia... • Answered on Oct 22, 2014
Insignia tv reset
Internal problem in the TV is enabling the protection circuitry. If repairing yourself, start with the power supply.
8/28/2014 2:14:59 AM • Insignia... • Answered on Aug 28, 2014
0answers
What is wrong with the power on my tv?
Sounds like main board fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter". http://electronicshelponline.blogspot.com/
6/22/2014 2:07:06 AM • Insignia... • Answered on Jun 22, 2014
Sound but no picture, Toshiba 22cv100u
Bad Inverter/power bd. or weak panel lamps causing no backlight.
4/5/2014 1:48:34 AM • Insignia... • Answered on Apr 05, 2014
0answers
Insignia NS-LCD42HD-09 42 in. HD-Ready LCD TV Logo
85 questions posted
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Insignia Televison & Video
Most Popular Question
insigna ns37d20sna14
  • Televison & Video
