fan won't start by itself.
SOURCE: Kenmore Refrigerator 596.72913200 refrigerator is cold and freezer is cold but nothing is frozen
hi lussed,
your problem is still poping up even though it was resolve already. i guessed you should rate a technician in this form as to delete the work from the list of jobs to do.. i am on the way to solve it but you had it solve with a real technician.
can you just rate me?...thanxs...
drcool299
SOURCE: Defrost problem on a LG Bottom Freezer Refrigerator
I had the same trouble. I found out if you have the digital display of temperature type of refrigerator adjust the freezer temperature to +5 degrees. The defrost systems uses a circuit board type. Not sure how it works. I took the back panel of and looked at the board. Did not see any manual defrost methods. I had to remove all the contents of the freezer and manually defrost. have not a problem since.
SOURCE: 16 month old GE Profile
see if the back wall inside of freezer have ice if so you have to change tiker board or check your doors if closing
SOURCE: Maytag Plus side-by-side freezer constantly needing to be defrosted
Water is collecting on the bottom of the freezer and freezes then it becomes so much it starts to leak out side the freezer door. get about 1/4" thick. Is there a leak some where? Take about 2 days to form.
