Try the standard start the laptop holding option and command and p and r (and hear that boot sound twice or three times; note that it gets louder)--this clears any info the laptop might be holding onto, like "I'm suspended with a blank screen". You can also unscrew the bottom plate and disconnect the battery, hit the power button to clear any residual power, reconnect the battery and screw back the plate (or maybe you just have a battery door to simplify!); then, maybe it boots, but I suspect...
...you screen is bad (since your hear the boot sound); to test: assuming your TV has an HDMI port, get a miniDP to HDMI cable (e.g. under $15 via Amazon slash dp slash B00APLKGA8); then physically connect, then change the input on your TV and hope there's a picture (e.g. your desktop background)--if you can't see anything, unplug and replug the thunderbolt/miniDP connector (or borrow any good laptop and verify you can see it on your TV)...
Assuming it's out of warranty (otherwise, you should be at the store already!), so pay $ to your nearest Apple store, or (for the brave) buy the part (hoping LCD panel; i.e. your TV saw a signal), and see repair guides via ifixit dot com (just note the super fine print on the bottom of your laptop; you'll need your Model No; A1286 or to do some searching).
I’m happy to assist further over the phone at
https://www.6ya.com/expert/shunter_ccf54e0913bd0501
