2001 Chrysler Town & Country Logo
Posted on Feb 24, 2009
2001 Town & Country Locking and Unlocking is Going Haywire
Our '01 T&C Limited is possessed!
First things first, remote won't do anything - - won't lock or unlock, won't set off panic, won't open any doors. Batteries have been changed, and still nothing (second remote that came with van was lost and never found, so we only have the one).
On occasion (and starting to happen more regularly) the van will just keep unlocking itself, driver side turn signal will flash, then passenger side, 10 sec's later same thing. This keeps up for sometimes up to 30 minutes.
Had in to local Goodyear for service (going there for 5 years, good techs reco'd as some of the best around by retired Napa Reg'l Mgr that is friend of family) and just my luck they couldn't get it to replicate the problem.
Other problems that may help solve: Lock with door button, and then unlock manually with key (not valet key) and the alarm goes off; and three weeks ago, passenger side door would open with overhead console button but not with interior button by the door itself - - now three weeks later both interior buttons open and close side door.
ARGGHHH! Like I said, POSSESSED!! Can anyone help? Thanks.
Anonymous
Level 1:
  • Contributor 22 Answers
  • Posted on Feb 24, 2009
Anonymous
Contributor
Level 1:
Answers
22
Questions
0
Helped
11739
Points
83
The body controller is at fault it may need the software update from the dealer... one thing you can do is disconnect the battery for about 5 minutes then when you reconnect it... the fob will work again...
2helpful
2answers
Why does my 2001 Chrysler town and country shake like it has a flat tire going on a highway but does not and it does not happen all the time
Check your tires for any "hot spot". Hot spots are created if car has been stored for a long time or from abrasion due tire locking from an emergency stop.
Door ajar light on and locks keep locking and unlocking
need to gain access to the BCM to see which door the module is seeing open. the locks won't lock with key in ignition and a door is "open"
1helpful
How do you change drivers side rear view mirror on 01 T&C Limited
  • remove the door trim at the mirror
  • remove the three bolts holding the mirror assembly
  • disconnect the electrical connector (assuming its powered mirror)
  • remove the mirror and replace
While drivingthe door locks sometimes start unlocking and locking
You have a bare wire that is rubbing. Take to your local dealership.
A/C on when 01 Chrysler T&C turned on
well two things first try to reprogram the a/c head cotrol second if this didnot work then you need the a/c head new one shorted out
2001 Town and Country Lock and Unlock is Going Haywire on its Own
Door Locks Go Crazy 1
Door Locks Go Crazy 2
Door Locks Go Crazy 3
Not to difficult to understand what's happening ,when you know how they work .Plus you need tool the proper tools to diagnose .
2helpful
200 suzuki swift central locking keeps locking/unlocking
suzuki swift central locking does not operate when using remote key fob
My Chrysler Town and Country Mini- Van won't stay started
Did you try inserting the key in the drivers side door and locking and unlocking it manually several times to reset the alarm system. This was the problem with my 1996 Chrysler Town & Country LXI
Top Chrysler Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Chrysler Expert? Answer questions, earn points and help others
