SOURCE: Cam Shaft Sensor Problems
Had the same problem before on my 04 Neon SXT...camshaft sensor is on left side of engine block, take out the battery and to the left of it (face car) is the camshaft position sensor. To change it you'll have to move a few hoses but its plan to see there on the left side of the engine...pretty easy remove and replace. Fixed my problem of car not going above 2k RPM when i replaced the sensor.
SOURCE: I need the location of MAF sensor in a 1998 Dodge
Your vehicle dose not have a maf sensor. They used a map sensor it is on the engine located under the front of the breater where it attaches to the engine.
P0068 - MAF/MAP Sensor throttle correlation
I suggest to check the snorkel going to the MAF (Mass Air Flow) sensor. Check for rips, cracks or if a tube has fallen off.
Hope helps.
