Posted on Feb 21, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to record with Multi-effects feature on Tascam DP 01
I would like to record the effect onto the track. I can hear the effect during recording but there is no effect on play back.
Glen
Level 2:
  • Expert 225 Answers
  • Posted on Feb 21, 2013
Glen
Expert
Level 2:
Answers
225
Questions
0
Helped
82343
Points
395
I'm not familiar with the Tascam DP-01 but many multi-track recorders don't commit effects to the track until the mixdown phase. The thinking being that you cannot eliminate a "bad choice" effect once it's down to tape (old school term) and so they allow adding the audio tweaks at the final stages of recording. Here they hope you can appreciate the entire mix and then decide what sweetners to add.
5 Related Answers
Anonymous
  • 189 Answers
  • Posted on Jul 24, 2008
SOURCE: what kind of driver does my tascam dp 01 cd take.
No CD comes with the DP-01. The Tascam relys on your computers USB drivers to work.
You should probably try the DP-01 on someones else's computer first to se if it works there.
This is usually some kind of incompatiblity between the usb cable or the use hub and the usb speed (1.1 or 2.0). I would try bypassing any usb hub you might have in use first. If that doesn't work you might want to try another usb cable.
Good luck.
bd.
Michial Gueffroy
  • 1140 Answers
  • Posted on May 30, 2009
SOURCE: effects won't record or play back
Turn on the effect for the appropriate input or turn on the reverb. For the reverb you must turn up at least one tracks (the track you are using) effects send together with the Master effects return. The volume of the multi effect may need adjusting or the parameter of the effect is so low that the effect is too subtle to be noticed. Multi effect page 60 of the manual. Manual can be found at http://www.tascam.com/products/dp-01;9,16,33,19.html under resources.
Fred Yearian
  • 5603 Answers
  • Posted on Sep 29, 2009
SOURCE: DP02- turning on an effect but not recording effect on track
You MIGHT try turning on the effect right after hitting record. It is possible that the record cancels the effects... I don't know if this is possible, but if it is, try it.
I can kind of see a technical reason they might do this.
Anonymous
  • Posted on Dec 10, 2009
SOURCE: Tascam MF-P01 recorder - hearing nothing during play back
Mine also would not play back on any of the channels but would record. The problem was on the lower board, capacitors C105, C205, C305 and C405, all are 220uF, rated at 10V - on a 9V machine! All four went leaky, which meant that the op-amps each were connected to got a bias which drove the output to 8.5V and no output.
I replaced all four capacitors with new ones rated at 25V and it works again!
Anonymous
  • Posted on Oct 22, 2010
SOURCE: tascam DP-01 master track too big to export
Here is what I did to solve this issue:
1. Open up the USB connection on your DP-01 so that you may plug into a computer:
MENU-
Effects won't record or play back
Need help DP-01 basic hook up to synthesizer
Midi on the DP-01 is only for time synching with another device, synth, etc. To hear your synth through the DP-01 run a 1/4" patch cord from the audio outs (R and L) on your synth into the A and B inputs of your DP-01. Then assign the inputs to tracks and arm them for recording. You should then be able to hear your synth playing out of whatever you are using to monitor you DP-01 (headphones, stereo or powered monitors). To record the synth output simply press play and record together on the tascam.
bd.
4answers
Poor Recording Level on the Tascam DP-02CF
When I record on DP-02/CF Tascam I can't get the music to play back. Do I have to do something other than rewind to be able to hear it? Albert S.
Guitar effects often disappear after recording
Hi Danny,
You seem to be aware already that the multi-effect acts like a traditional 'insert effect' on a mixer and as such can only be applied to one track/channel at a time (multiple effects / single channel). The problem you're asking about seems to be that the effect is not 'printing' during the recording of your track. Obviously the effect can't 'go away' after recording so it would appear that your guitar effect isn't being recorded (only monitored) when the track is being laid down.
My initial guess here would be that while recording you've been assigning the multi-effect to a channel vs an input. That would explain the effect being audible while monitoring, but the input still being recorded dry even though the effect is heard through the monitors.
So to get this working the way you expect you'd want to insure that you are indeed assigning the multi-effect to input from which your guitar is coming, rather than the track on which it is getting recorded.
Having said that, actually recording dry (like you are doing) and then applying the multi-effect to a new track via a 'bounce' is the way a lot of people (myself included) choose to accomplish this anyway. That way you preserve a dry track and can go back and 'redo' the effect (or choose a different effect instead) later on. It does however introduce another step and use up another virtual track (but the 2488 has 250 of them available which si a big reason the 2488 is so competitive).
Hope this helps.
bd.
2helpful
Vocal effects on Tascam 2488 MK 2 portable studio
Hi again,
The easiest way to record using an external Lexicon effects unit (without an external mixer) is to connect your mic onto one of the 2488's inputs and assign that input to a channel strip (track). You should have the 2488 sends (output) going to the Lexicon's inputs. Then connect the Lexicon outputs back into another set of inputs on your 2488 and assign those inputs to two empty channel strips (tracks).
Then you will have to take that channel that has your mic input assigned to it and press send and set the levels there to send the signal out the sends (to the Lexicon).
Now you have a channel strip assigned to the mic input which contains your dry signal, and you have the two inputs returning from the Lexicon which contains your wet or effected signal.
You then have some options. You can control the amount of effected signal you hear while recording by adjusting the faders of the two wet tracks and you can either record the dry signal or the wet signal (or both) onto separate tracks.
Typically when recording the singer will want to hear an effect (say reverb) on his voice, but the engineer wants to record only the dry track at recording time (because effects can always be added later, but they can't be taken out). To accomplish this you would use the setup above, but only arm the mic input track for recording. In this way the singer hears the reverb, but only the dry vocals get recorded and the engineer can add reverb to that track again later as desired (and mix it back with the dry vocal etc).
On the other hand if you want to record only the effected signal you would simply arm the two channels to which the inputs coming back from your Lexicon are assigned for recording. This will get you a recording of the effected signal only.
Hope this helps you do what you are trying to do.
Cheers.
bd.
Is there any way to record Tascam 2488 Multieffects directly to the hard drive when I record? When I change tracks during playback, the previous effect that I used disappears...Please help???
Yes. Rather than pressing the track SELECT button to assign the effect, press one of the SOURCE buttons to the left of the EFFECTS. This will record the effect HARD to the track as oopposed to SOFT. SOFT being that the effect will NOT be recorded whereas HARD means it IS recorded and will be there anytime you play the track. NOTE: Just make sure that's the effect you want as it is then part of the track.
DJ EQUIPMENT
Lot of possibilities.
The DP-01 is like a mixer with built-in recording capabilies. You could plug your tunrntables into your DP-01 inputs, assign the inputs to tracks(channels) on the DP-01, and then output those tracks to two channels on your mixer (which would be connected to your PA.
Alternatively, you could plug the outs from your mixer into the DP-01 either by routing individual channels from the mixer into the DP-01 inputs, or outputting the mix into a single track (or into two tracks in stereo on your DP-01). Just assign the DP-01 inputs as usual to the tracks you want to record onto.
Those are just a couple of basic ideas. You could also route a DP-01 track (or the whole mix) back out the DP-01 send loop and through some external processors and then back to tracks on your DP-01, or you could do this through the mixer and then record the final result on the DP-01.
Top Tascam Audio Players & Recorders Experts
John
John
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
