I've tried adjustments on the powered speaker's dials such as; the "sub" button; adjusting it as I push the "sub" jack in and out of its plug at the back of this same speaker. It has four buttons: On/off vol., center, surround and sub. That's all that I've tried so far. It acts as if it has a short in the circuitry some place.
SOURCE: Sub Woofer does not work
hi there are fast checkings for you: Quick Connect Card http://www.alteclansing.com/downloads/641QCC.pdf manual: http://www.alteclansing.com/downloads/641_MAN.pdf is the system working fine exept the sub? my guess: the headphone jack works fine then the speakears are too if soo then the sub amp is bad or some connection is torn try opening the sub and see if everything is hooked right and if soo then the amp is the problem every electronics shop can fix this good luck
SOURCE: I only hear sound out of two speakers........
Have you set the computer up for 4.1 speakers in the audio software? Go to start control panel and click on sound's speech and audio device's, then click on sound's and audio device's. A window should pop up with a load of menus at the top, click on the one that says volume. Where it says speaker settings click on the advanced button. Click on the menus until the picture lookslike your system you have.
SOURCE: center & sub-woofer problem
The outputs may have died if this is the case you will need to get them fixed by a proffesional
SOURCE: Getting humming sound from all speakers. BA 700569 MicroMedia
It sounds more like the power supply is at fault (a filter capacitor dried up), but it'll take an oscilloscope to verify that - take it to a TV repair shop (if you can find one) or find a ham radio operator who still has test equipment. (If it happens even from an iPod, it'll be easy to troubleshoot, since the person doing it can use any audio source to cause the problem.)
SOURCE: I am only getting sound from the two rear speakers
other tha a 3 way speaker adapter you need to get a 5.1 surround sound card
