I would like the sounds generated by the pc to be routed through the receiver to my floorstanding speakers.I don't see the typical red and white RCA connections on the back of the dell
The audio output jacks on the back of your computer are for 5.1 speaker setup. Meaning that you have a speaker array of 2 front side speakers, 1 center speaker, 2 rear left and right speakers and a sub-woofer speaker. Here is a link to the set-up giude of your computer:
ftp://ftp.dell.com/Manuals/all-products/esuprt_desktop/esuprt_studio_desktop/studio-desktop_Setup%20Guide_en-us.pdf
SOURCE: No sound on my pc
Go to Control Panel, Sounds and Audio Devices
Ensure that sound card is the default playback and default recording device.
Also, if this is a Dimension 5100, then there is a possibility that the system has a upgrade sound card installed in a PCI expansion slot (Below the video card)
If the system has an expansion card, (Soundblaster) then the integrated on-board audio should be disabled in the BIOS (If integrated is on and an expansion card is installed, you get a conflict and no sound) Normally, if the system has an expansion card, the ports are covered with a black plastic cover. If the BIOS defaults are ever reset, then onboard audio needs to be disabled again.
SOURCE: Dell Studio 540 MT No connection from PC to
in this case it is probably the video card ...so ..if you have a on board one ...just move the cable to it..(its placed near the other on board plugs like usb and printer plug ) but you may need to remove the faulty card from the computer in order to let the on board one to work ...also try to see if it is not just a case of plugging the card better in the slot ..or so ...there can not be anything else cause if the monitor says there is no signal this is the only issue possible..if the computer starts ....
SOURCE: dell dimension 1100 drivers but can't download
Audio Driver you can download hereChipset driver hereLAN Driver here
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes. If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. Check the memory module and memory slot contacts. They are either copper tin or gold. The colour will tell you which they are. Mixing tin and gold can result in corrosion that prevents proper contact. Look for any sign of physical damage to the memory module, memory slots or the motherboard. Reseat the memory modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible. Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ There is a connection problem such as a bad cable for internal hard drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide this will be the first to fail Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty. or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Hope this helps.
