20 Most Recent Logitech X-540 Multimedia Surround Sound Speaker System (6-Piece) Questions & Answers
Hook mz506 surround sound to my Samsung tv
Typically surround sound is run through a receiver or stereo. The sound from the tv is carried to the receiver by cables (hdmi or Audio-Video connected to input area of receiver). Then the speakers are connected to the output area of the receiver.
If you are not using a receiver, then the speakers must be able to connect directly to the tv and you have to see what kind of cabling your tv supports.
1/27/2015 2:55:23 AM • Logitech X-540... • Answered on Jan 27, 2015
0answers
X540 remote
Be the first to answer 8/22/2013 4:17:36 AM • Logitech X-540... • Posted on Aug 22, 2013Be the first to answer
0answers
Puck board
Be the first to answer 5/19/2013 7:27:38 PM • Logitech X-540... • Posted on May 19, 2013Be the first to answer
2answers
The mains transformer in my logitech x540 has
You would need to rewind the coils.Do not try to do it by yourself if you have no idea what you are up-to...this time it was transformer next time it could it could be your circuit.Take it to a professional,the charges won't be much.
Good Luck.
12/11/2011 1:35:39 AM • Logitech X-540... • Answered on Dec 11, 2011
Speakers not working
Follow this checklist:
1) Make sure they're securely plugged into the wall
2) Make sure that any relevant power switches are in the "on" position. Is there one one the subwoofer?
3) Make sure they're securely plugged into your computer (or other device)
4) Make sure that the source device is actually outputting sound. Try plugging headphones directly into the computer
If these fail, please come back with more details. Are there any indicator lights/LEDs on the speakers? If so, do they light up when plugged in and turned on?
3/1/2011 1:02:42 AM • Logitech X-540... • Answered on Mar 01, 2011
I have a new dell inspiron. I just purchased
Yes there has to be a configuration for the 5.4 surround sound... look if the hardware came with a CD to update the sound driver. or Check if the its correctly configured. on the control panel then click Sound, then depending what windows you have have to lookk for the configuration or properties area and configure as 5.0 or sorround etc.
2/26/2010 2:18:12 AM • Logitech X-540... • Answered on Feb 26, 2010
Logitech x-540 how to plug it into my HP computer
Have you got a 5.1or 7.1 surround sound card?
2/4/2010 8:30:51 PM • Logitech X-540... • Answered on Feb 04, 2010
[logitech 5.1 x-540] my front speakers arent work
Go through systematically and check all connections. Start at your PC. Is the soundcard set-up correctly? Is it set to 5.1, stereo? Next, look at the wires. Are each of the wires plugged into the correct places? (you may need to refer to an instruction manual for this) At the other end of the wire, are they plugged into the right places on the back of the subwoofer? Are the front satellites plugged into the right places? After this, are the speakers themselves functional?
Usually, I find it's a connection along the way, nothing more serious.
You may have a more serious problem, in which case it would be difficult to fix, but for now, there's a simple check for you.
1/11/2010 8:46:53 PM • Logitech X-540... • Answered on Jan 11, 2010
Compatiblity
Hi there , Please before you buy it ,make sure that the laptop you have has a 5.1 Channel Sound Card , if it doesnt you will not be able to use it...if it does then yes you can buy it and use it.
Thanks
12/29/2009 10:59:36 PM • Logitech X-540... • Answered on Dec 29, 2009
I have the logitech x-540 5.1 speaker system, do i
Yes, you do, the adapter has 1 green end, which gets plugged into your computer and then the other end has 3 connectors, green, yellow, and black, which then goes into one thick cable. I have the set up right now.
12/3/2009 4:09:17 AM • Logitech X-540... • Answered on Dec 03, 2009
X540 speakers only playing test sounds through front and centre
it may just be the way the card was programed
6/23/2009 12:14:04 AM • Logitech X-540... • Answered on Jun 23, 2009
Rear and Centre speakers not working
The system comes with l remote which provides controls for "Power", "Master Volume", "Bass (Subwoofer) Volume" and "Matrix Mode" . Matrix mode allows you to spread stereo sound to all speakers where your sound card may not have the ability to do so.
I find that the "Stereo Surround" setting works best as opposed to the recommended "CMSS" setting
3/9/2009 2:15:00 AM • Logitech X-540... • Answered on Mar 09, 2009
LogitechX540 speakers hooked them up to our PC makes raspy sound
you might try putting in a new sound card to see if that dosent help. it should take care of the problem
1/11/2009 7:46:23 PM • Logitech X-540... • Answered on Jan 11, 2009
Logitech X-540 Multimedia Surround Sound Speaker System (6-Piece) Logo
31 questions posted
Top Logitech Audio Players & Recorders Experts
Paul Bade
 Grubhead
Grubhead
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Logitech Audio Players & Recorders
Most Popular Question
logitechx540 speakers hooked up our pc
  • Audio Players & Recorders
