Optics Logo
Sirri sentur Posted on Feb 14, 2013
I have Fujinon stabiscope s1440 The older one 14x40 4 . I need battery holder, for 6x aa battery holder. Regards . Steve.
Da Foccer
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 27, 2013
Da Foccer
Contributor
Level 1:
Answers
Questions
0
Helped
526
Points
0
1helpful
Techno stabil 14x40 . yellow light comes on. Green light wont follow. Pwr button will not turn off pwr . of course if gr does not come on no IS
Hi.
The binocular is behavior is the same as when the electronic control module is defective. First try resetting the electronics by pulling out and putting back the AA batteries. The power reset in some occasion may unlock a jammed control module. If you have an external power adapter also test the binocular using the power adapter.
If that does not help the control board must be replaced. Disassembling of optical units is quite delicate and require experience. In that case I suggest contacting Fuji to get support. You can also get a quote on repair from a third party service. Here the online form: Repair Form.
Here some contacts. You will find your local Fujinon contact on the user manual provided with the binocular:
FUJINON INC.
10 HIGH POINT DRIVE, WAYNE, NJ 07470 U.S.A.
TEL:973-633-5600 FAX: 973-694-8299
FUJINON (EUROPE) GmbH
2 HALSKESTRASSE 4, 47877 WILLIcH, GERMANY
TEL: 2159-528545 FAX: 21 59-51 315
See also : Technical Service
Regards.
Ginko
Cant find batteries I live in Georgia
Depending on the battery holder, you can use AA, AAA, lithium.
If you have lithium battery holder, buy AAA battery holder or AA battery holder from eBay.
1helpful
I have an old ''Fountain P.C.'' with an INTEL 80386/25NC motherboard, ca. 1990-98. The memory backup rechargable battery is shot. The battery is 3.6volt 50mAh sealed NiCd with solder tabs at each end,...
I use to use a AA battery holder purchased from Radio shack and 4 rechargeable AA and solder them in place and that should do the trick.\
2. you can do a google for All Electronics to see if they have the correct battery to insert in to the holder.
Hope this helps/ this may or may not work due to the motherboard configuration. I have used it in the past on older boards that needed a battery that was hard to find or no longer manufactured.
Need Minolta Maxxum 7000 battery holder
hi, I have a spare battery holder for minolta 7000 model, if you are still interested.
Best regards
Bob
Fujino Stabiscope S1240d/N
I don't know about the night vision bits but if it is the same as S-1240 then the 3-pin plug is a power input.
Regards,
Tony
Stableizer not working
Baker Marine in CA will fix your Stabiscope. They told me $1500 minimum for the same problem. They are the only ones in the Western World that fix these things, truly. I know of a guy in Denmark who was told to send his to Baker. They have no competition nor any canscience!!
Type of batteries
You can use two LB-01E 3V lithium batteries, four B-01 4PE AA Ni-MH batteries (BU-40SU charger and batteries), four AA Ni-CD batteries, four AA Alkaline batteries the B-10LPB Lithium Polymer Battery or the New B-12LPB Lithium Polymer Battery . Please note: the B-10LPB Lithium Polymer Battery, B-HLD10 Power Battery Holder and the B-20LPCE charger are included in the B-30 LBS kit, and the B-12LPB Lithium Polymer Battery, B-HLD10 Power Battery Holder and the B-20LPCE charger are included in the B-32 LBS kit.
Batteries
The E-10/20N battery holders are designed to fit the longer type CRV-3 lithium batteries and conventional sized AA NiMH batteries. Once installed into the battery compartment the AA sized batteries will make an electrical contact with the camera
Top Fuji Optics Experts
ADMIN Andrew
ADMIN Andrew
Tony Parsons
Tony Parsons
Are you a Fuji Optic Expert? Answer questions, earn points and help others
