Checked sound defaults...everything seems good. Computer sound is up, options on the computer control panel is good. the account is active.
If you're missing Skype calls because you can't hear the ringtone, it's time to crank up the volume. There are three different ways to increase the ringtone: within the Skype client, within your operating system's volume settings and by adjusting your physical speakers or headset. You might find it necessary to adjust all three settings to get the proper volume. You also must set your Skype status to "Available," because a "Busy" status disables the ring from incoming calls.
Launch Skype. Open the "Help" menu. Select "Options." Select "Audio Settings" from the left sidebar of the Options window. Find the "Speakers" listing. Uncheck the "Automatically Adjust Speaker Settings" box. Slide the blue volume slider to the right to increase the volume. Press the green play button to test the volume. Skype plays a default ringtone to test the sound. Adjust your computer's sound settings. Windows users, click the speaker icon in the taskbar located at the bottom right of your screen. Move the slider up to increase the volume. Mac users, open the "Apple" menu. Select "System Preferences" and click "Sound." Drag the slider to the right to increase the volume. Turn up the volume on your speakers or headset. Desktop speakers can be adjusted by turning the knob on the front of the main speaker. Headsets sometimes have a small button that can be pressed up and down to adjust the volume, depending on the model.
SOURCE: built in Webcam won't work with skype
If you use your webcam in different programs it may be still hooked up on one. Try re-booting your webcam software
Mine, I just unplug it and plug it back in.
As yours is built in - expand the imaging folder in Device Manager - Right click on the webcam text and toggle between 'disable' and 'enable' leaving it disabled for a few seconds - long enough to re-boot.
SOURCE: video is upside down in skype.
Connect webcam
Open Skype > Options > Video Settings > Webcam settings > Advanced
Toggle your Mirror image vertical
See if the Mirror image horizontal is ok - change if necessary
SAVE
