I am trying to get the inside of the door off to see what is wrong with the window mechanisim for the life of me I can't figure it out. Looked in the owners manual it states nothing to this problem. There are no screws to undo please if someone could tell me the trick I would so appreciate it
You did not mention whether it was a front or rear door? I assume its a front because u stated no screws.
Here are instructions for front door:
Remove the plastic trim from behind mirror(just snaps on).
Remove the window switch panel(just snaps on).
Remove the screw behind the mirror cover.
Remove the screw behind the window switch panel.
Remove the courtesy lamp lens.
Remove the screw in the courtesy lamp housing.
Remove the inside door handle trim cover.
Remove the inside door handle bolt.
Lift upward and then outward to remove the front door trim panel
