Hard to get battery in right position to charge
SOURCE: Schumacker battery charger problem?
You are charging. The meter corresponds to the level of charge in the battery. Try setting to 10 A for 4 hours, battery should be half-way up. To determine if battery id dead.. leave battery off charger once it is fully charged...test with a voltmeter after 10 min.....battery should still be above 12v...after1 hour it should still be above 12v...if not battery is spent.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
SOURCE: charger to computer connection intermittent
You will have to take it to a techie and have a new d/c jack installed on the motherboard. Easy job, but want to know what you are doing. About $60us in my market for jack and labor.
Good luck, and please rate this response.
SOURCE: 14.4V Drill Battery Will not Charge
The battery is 14.4 volts so the charger should be 14.4 volts.
SOURCE: I have a Dayton battery
Make sure you have the charger set to conventional battery or deep cycle depending on the battery you are charging. Set it to 6 volt, and 10 amps. If the battery will not take a charge it more than likely has a dead cell. Take the battery to anyplace that sells batteries and have it tested. A battery with a dead cell will not accept a charge.
SOURCE: need a 3 position switch for a Schumacher model se-2352 battery charger
Chornic Quick Charger 2 0 2port QC2 0 4port USB Charger 5V 9V 12V 60W USB...
