Ademco 5716 Wireless Door Window Contact Rare 5700 Logo
A
Anonymous Posted on Feb 04, 2013
5716 where can i find a good one?
1helpful
Light does not shut off
I have had a lot of problems with this model of sensor. I bought 6 a few months ago and they all are bad. I have since switch to a different model sl-5315-wh-a and all seems good again. I got them from Lowes. I think that they were around $23 each. I have been using these type sensors on my house for 20 years and have replaced them all at least 2 times.
Hope this helps
1helpful
Looking to build using hp 5716 case. need to know where to find out what mb will fit case.
The size of a motherboard, is the Motherboard Form Factor.
I'm willing to bet the Presario 5716 uses the Micro-ATX form factor, but could be wrong, and it could be the ATX form factor.
I base this belief on the factor, that I think the Presario 5716 uses a Mid Tower size of computer case.
The motherboard Micro-ATX form factor size, is 9.6 inches by 9.6 inches.
(9.6 inches is about 9 and 5/8th's inches.
5/8th's of an inch = .625)
Metric conversion for the above is 244mm by 244mm)
The ATX form factor size is 9.6 inches by 12 inches. (244mm by 305mm)
Inside the computer case is a Support Plate. The Support Plate, is what the motherboard screws down to.
Sometimes it's a separate piece, but for the Presario 5716 it's probably riveted to the case.
Looking at the Support Plate, you may notice the abbreviations mATX, and ATX by the motherboard mounting holes on the Support Plate.
mATX standing for Micro-ATX, and ATX standing for the ATX motherboard size.
This will be more readily spotted with the motherboard removed.
If so you can use either form factor of motherboard. You may Not be able to reuse the I/O plate, (I/O Shield), at the rear of the computer case. (Input/Output shield - plate)
The shiny rectangular, thin piece of metal, that covers the I/O ports. (Examples: Mouse, Keyboard, and Monitor to name a few I/O ports)
This rectangular plate pops out with a BIT of persuasion. The new motherboard should come with it's own matching I/O Shield.
WARNING!
The inside edges of the computer case, where the I/O Shield is mounted, are SHARP!! Use extreme caution, and perhaps gloves to remove the I/O Shield.
Once the old I/O Shield is removed, it is readily apparent of how to install the new one, and could avoid possible confusion of me trying to explain here.
Sometimes the I/O Shield that comes with the new motherboard is not a direct replacement, as to fitting in the existing rectangular hole, in the computer case.
In this instance, a little modification is in order to the computer case.
(IF so, remember to smooth the edges with a file)
This link to Wikipedia explains the motherboard form factor pretty well, and also has photos, and charts,
http://en.wikipedia.org/wiki/Motherboard_form_factor
(You can click on any photo to enlarge it. There is a chart at the bottom of the page)
Now you know,
A) Motherboard Form Factor
You can measure the old motherboard for it's size, and know what form factor it is.
B) Support Plate, and the mATX, and ATX designations that may be stamped, or printed near the motherboard mounting holes, on the Support Plate.
If the old motherboard is not obtainable, you can look for the above designations, to see what motherboard form factors apply.
You can also use a tape measure, and measure the distance in-between the mounting holes, and obtain a rough guess.
It won't be that rough a guess, when differentiating between 9.6 inches, and 12 inches.
C) When looking at a website that sells motherboards, you can look in the specifications description, and look for the designation ATX, or MATX, to see if that particular motherboard will fit in your Presario 5716 computer case.
(mATX, and MATX = Micro-ATX)
As for buying a motherboard that will equal the specifications of your old motherboard, good luck.
You can buy an exceedingly cheap motherboard now, that will outperform your old one, like a dragster flying by a snail, in comparison.
You won't be able to reuse the old Processor, and is doubtful that you can reuse the Ram Memory.
The Ram Memory, is SDR Sdram, that operates at a frequency rate of 100MHz FSB. (PC100)
(Single Data Rate Sdram is commonly just referred to as Sdram. Speed is slang for Frequency Rate)
The Processor, is either an Intel Pentium III that fits in a Slot 1 processor socket, or the Pentium III type that fits in a Socket 370 processors socket.
The Pentium III processor, that fits in a Slot 1 processor socket, is about 5-1/4 inches long, and 3 inches tall. It should have a black plastic case around it. Thickness is around 3/4th's of an inch.
The Pentium III processor that fits in a Socket 370 processor socket, is about 1-1/2 inches by 1-1/2 inches, and is square.
The Pentium III processor used in the Compaq Presario 5716 operates at a maximum frequency rate of 450MHz. (MegaHertz)
This gives you an indication, of what a Pentium III Slot 1 processor looks like,
http://www.cpu-world.com/CPUs/Pentium-III/Intel-Pentium%20III%20450%20-%2080525PY450512%20%28BX80525U450512%20-%20BX80525U450512E%29.html
Can i get a user manual for Whirlpool washing
46846UJNVG JHY65T8U 6RHYI6RI95 875IKJYJ
Lost the manual for the Oster Rice Cooker 5716. Do you know where I can find one?
If manufacturer site is of no help, check here, they can get it for you.
USB ports
When you computer boots up you need to enter the cmos mode. Normallly it's the F-8 fuction key, but sometimes it can vary from pc to co. When you get inside the CMOS screen look for the usb ports, they should have a Enable/Disable. I am pretty sure that for some reason, the default is Disable.
Try this and let me know if this fixes the issue.
Jack
CD will not open Compaq 5716
Four/five year old Compaq system boards also develop leaks in some of the capacitors that cause the IDE channels to develop read problems. Look for signs of "damage" near the IDE cable connectors.
In addition, the error recovery of the Windows Setup program is, well "really bad". It can not handle CD-Rom or CD errors very well. With this type of problem you have to boot with a startup diskette and see if you can read most of the disk drive. Then create a work folder on the disk drive and copy the contents of the WinXP folder to the temp folder on the disk drive. Then run the Setup from the disk drive.
In some cases like this, you have pull out the CD-Rom drive and if it is on its own IDE cable, change Compaq's default jumper setting from CS (Cable Select) to MS (Master). Usually works a lot better.
The reason you have not had "any trouble" with the drive (that you know about) is that Windows has very good error recover, it just keeps trying, and does not tell you about problems unless there is nothing it can do to get around the problem.
Try a different CD. Can be a bad CD.
Try looking at device manager to confirm that the PC sees the drive.
Right-click on MY Computer and select properties
Go to Hardware and select Device Manager
Try using a CD cleaner as the laser that reads the CD is dirty.
2answers
No sound and will not allow me to install or play scrabble pc game or any cd
i am sorry, but being a computer idiot i don't know what os i am running nor do know how to find out
Top Ademco Home Security Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you an Ademco Home Security Expert? Answer questions, earn points and help others
