It has a triac or scr in the input that is burnt and the hv xistor has no markings that can be read
SOURCE: Alpine XL 15 not working after cleaning
Bottom small plastic covered screw is a trigger for interlock switch, won't work if it doesn't push in the metal trigger.
SOURCE: I need Alpine Air XL-15 Air Purifier Repair service
Best bet is to call EcoQuest at 1-800-989-2299 and they can direct you to the closest repair center.
There is also a way to upgrade to a newer model the FreshAir 2.1 getting $100 back for your old XL-15.
To do this go to www.healthylivingia.com or call 1-800-798-6925 and ask for Eric.
SOURCE: Round Metal Disk type thing in Alpine Living Air XL-15
Hi Chipster7_20,
It sounds like the little round electrical spade terminal is what has broken off. If you aren't comfortable working with electrical (this is a fairly high-voltage environment, BTW), you might want to find a local electrical repairman to replace and re-attach it. EcoQuest no longer does support for XL15s, so it's up to little independent dealers/handymen like yours truly to keep these machines going. You could ship it to me, but it would probably cost more for shipping than having a local do the work.
If I mis-understood your description, please write back with more details. If you could reply with a digital picture it would help. (use the little tree-picture icon in the toolbar above to post it).
If I can be of further assistance, or if you have questions about any of my response(s), please let me know before rating me.
If this solves the issue, please rate it accordingly. My goal is to earn a "FixYa" rating from everyone I help.
Thanks for using Fixya.com,
Jon
SOURCE: My Alpine Air XL-15 Air Purifier youst to have a
The Classic XL-15 should have 2 individual indicator lights. The 'red' light is the ionizer indicator, and the 'green' light is the ozone level indicator. Both lights should be illuminated, if the unit is operating properly. The red light should be pulsing, and the green light should be dimly lit, and brightened as the output knob is turned up - indicating a higher ozone production. If the green light is not lit, you likely won't smell the ozone. The first thing you should try, is cleaning the filter and glass ozone plate. Unplug the unit and remove the rear air filter. Clean the filter with clean water and allow to COMPLETELY air dry. Removed the glass plate by depressing the lever behind the glass plate, and gently pulling it out. Clean the glass with a half water, half ammonia (or distilled white vinegar, if ammonia not available) and an old toothbrush to clean between the mesh. Dry plate with a hair dryer and re-place plate into unit. Replace dried air filter, making sure the little tab on the bottom is secured into the interlock. Power the unit on and you should see the indicator lights and smell the fresh ozone!
SOURCE: I just purchased a used Alpine Air XL-15 from ebay.no ozone spell
You probably have a burned out high voltage transformer. That's what produces the ozone. Helpful hint...........the high voltage transformer is also the one used in bug zappers
