Click this link: Door lock
SOURCE: BOSCH SGS6302GB
Hi nikkij
It is simple to put them back on. the plastic pices fit on the bottom of the hinges. there is a cut out where they fit in. when you look at the door at the bottom you will see the hinges and the cut outs, the plastic pices fit in the cut outs flat side in. hope this helps
SOURCE: Bosch Dishwasher Model SHU66C soap door will not open
This is most likely the actuator for the soap door. Unplug and remove door covers to find it, and check it is not seized. Look at "wax motor" online to understand working, as they often use these (and may appear siezed - when actually ok)
Check cables are not broken and connectors not corroded.
Replace actuator if you are uncertain, and try again.
Further problems may be the contact to control it in the controller assembly or a broken cable between the two.
