I have an error code F2-31 that I cannot clear
SOURCE: Sharp AR-507 code E7-00
ICU Communication error. Could be a problem with the ICU board or the connection between it and the PCU board. If resetting the machine (main power off and on) does not solve the problem you'll likely need a service call from a copier tech.
SOURCE: I have a Sharp AR-507. Error F2-00. How to fix?
It could also be the sponge roller in the toner hopper. The old ones started to deteriorate after a while so sharp modified them.
SOURCE: How can I get the error codes of my Sharp AR-507 and how to clear
Press the "P" key, the "Interupt" key, the "C" key then the "Interupt" key.
Once you enter the Simulation Mode, then "2,2, start (Print Key) will show the jam, service counters, and 2,4 start (Print Key)"will allow you to clear the counters.
To clear certain codes, once you enter the Simulation Mode, then enter "13 or 14 or 15 or 15 then start". Depending on the code will depend on which "number" you need to execute. (It doesn't hurt to do all the numbers."
SOURCE: error code h5-01 appeared on my sharpmar-507
Check the fuser unit and make sure its installed correctly.
SOURCE: sharpe ar-163 with error code u-240
Hello sir; The error code you display is CRUM communication error.
