Since we got the vehicle the lights and a/c blower would occasionally glitch and go out. About a month ago it died and we jumped it off. everything went haywire momentarily then went back to normal. From that point my dashboard sensors would go on and off. The other day while i was driving the radio died, then the dashboard, then the power locks and window,then the power-steering, then eventually the motor died. its ironic though bc my sons dvd player still worked. Ever since then the whole truck has been completely dead, doesnt run and we have to manually do everything.
Test your positive and negative cables for continuity. Sounds like you have a cable not doing the job. Also be sure to check connection is secure
SOURCE: 03 chevy silverado, problem with
if the alternater light is not on the battery.probably has a bad cell
SOURCE: 97 Chevy Blazer - good battery, good alternator...still dies???
if you removed the dome lightbulb then there is no longer a draw from the battery there but if the ashtray light light does not go out then over a period the battery will go dead or drained to the point to not the vehicle
SOURCE: starts then dies immediately, drained my battery
Is the security light blinking when it dies?
check battery voltage when you turn off car. it should be 12.5 volts.if drops 11.0 volts the battery is got a weak cell in it.i bought a sears die hard battery it last 2 years the battery had a defect .it had a bad cell it short out the battery.check alternator wires for defects.
SOURCE: starts then dies immediately, all inside
on chevy malibu, turn key on engine off.let it stay on 10 to 15 minutes. then turn ignition off, take out key from ignition. after a minute start the car. this should work.
