Rear door locks are locked permanently
Your Tempo is equipped with early child-proof rear door locks...(cannot open from the inside when locked) Open the doors from the outside and look near the door catch for a small switch that moves back and forth...if still labeled it should show "Lock...Unlock" marks...leave on unlock for normal opening from inside. Hope this helps.
SOURCE: Rear door dosn't lock
the problem is the lock actuator . it needs to be replaced and its no easy job
SOURCE: Rear Door will not Lock
After researching this problem, I suspect it is the door lock actuator located in each affected door. They can be purchased online. If you also suspect this and want to fix it yourself by removing the door panel and the old actuator, then installing the new actuator, test the locks, then install the door panel. Or for more detailed information, go to this website for a how to with pictures and written instructions. http://www.ford-trucks.com/user_gallery/displayalbum.php?&albumid=12198
SOURCE: 2000 Ford Focus electric locks/acuator failure recurring problem
I would follow their recommendation as I had the same problem with my car. They unhooked the power to that door and it was fine. The problem was a short in the wiring in the door that was causing the problem. So maybe get them to check the wiring in the door as well.
SOURCE: 2002 Ford Explorer - Drivers side door lock, rear
Aside from the fuses, your drive side power door lock may be failing to work because of a bad door-lock relay system, or, alternatively, the locking switch/button, itself, is not malfunctioning and in need of replacement.
A great handyman site that specifies the above probable causes and more is the following link:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Vehicle_Car_Zone_Cars_Trucks_Vans_Locks_Power_Locks_Do_Not_Lock_When_Pressing_Locking_Switch_Button.htm
SOURCE: my power door locks dont work can not get into the
1998 door locks wont work neither does keyless entry
