GE 30 in.Profile JGP940 Gas Cooktop Logo
Posted on May 01, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Gas leak in my GE profile JGP336
I detected gas leak in my GE JGP336. At first, one of the burner leaks even its control knobs is in off position (I can ignite that burner with a match without switch control knob to on position). I felt that the control knob is hard to turn, so I removed the control knob and cleaned the dirt underneath the knob. After that, the burner no longer leak. However, now that control knob has gas leak. I can detected the gas leak but don't know what can I do. The leak is from place beneath the plastic part. I need to seal it or replace it. How do I fix this?
Marvin
Level 3:
Top Expert:
  • GE Master 85,242 Answers
  • Posted on May 01, 2017
Marvin
GE Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29061077
Points
266281
Contact your local gas company and turn off the gas to the unit.
3 Related Answers
Anonymous
  • 530 Answers
  • Posted on Feb 15, 2010
SOURCE: GE profile gas cooktop - sparker firing with knobs turned off?
replace your spark module
have you spilled liquid on the cooktop recently?
if yes let it dry for a couple of days and see what happens.
sometimes when you spill liquid on the cooktop it grounds out the spark module and it will continue to spark until it drys.
let me know if you need more help
Anonymous
  • 43501 Answers
  • Posted on Aug 30, 2010
SOURCE: 30 in. JGP336 Gas Cooktop: We have a GE model # JGP933SEK2SS gas cooktop. ...
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
lincoln jeon
  • 12 Answers
  • Posted on Feb 17, 2014
you have moisture buildup in the switch,
you can blow dry it to dry it out.
or the contacts in the switch or switches are connected together.
or grease build up.
you have to open , take apart the cooktop to test to figure out which switches are bad., you can do this by unplugging each switch and testing it.
be causes.
once you figure out the bad switch or switches, you can order new parts, or drill open old switch to clean out and fix the switch for re use.
basically,
1, clean mositure
2. clean contact points
3. test to see if the switch works, by turning the wheel and check contact points.
4. crazy glue back.
5. put back and use.
New Maytag MGC7430 gas cooktop leaks gas when lit
First it could be leaking from the control knob when it is on . There could be a leak at the base off the burner letting out gas or on the burner line . You need to get back on to your installer or where you purchased the cook top . This basic gas fitting leak detection .
3helpful
My GE Profile propane gas cook top was just installed yesterday. When I go to turn on one of the burners, all of the ignitors click. This can't possibly be normal. Anyone else have this issue?
Yes, thats okay when you turn the knob voltage gets sent to the spark module, Then the module sparks all the burner igniter. And frame ignition only happens on the single burner of the knob you turned that sends gas to the burner associated with that knob.
Please rate me a "4" if this information was useful.
2answers
heatman101
Dcs igniters
clean the knob control by using vaccium,pull the knobs then clean it.make sure how to remove the knob,same position to returrn the knob
2answers
Ticking sound of gas igniter continues after off.
try to clean the place wen u remove the control knob,by using a vacium.
Nov 19, 2008 • Cooktops
2helpful
Ge profile ceramic electric cooktop
No recalls that I know of.  The switch for that burner has shorted and will need to be replaced.  It will be fine once it is repaired.
Top GE Cooktops Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a GE Cooktop Expert? Answer questions, earn points and help others
