20 Most Recent GE Monogram ZEU36 Electric Cooktop Questions & Answers
Igniter issue for monogram gas cooktop
Be sure all caps are on correctly, then make sure the igniter is clean. Try using a tooth brush with soft scrub around the igniter, rinse, dry and try it always unplug electricity before attempting to repair on any electrical appliance
10/26/2019 12:14:44 AM • GE Monogram... • Answered on Oct 26, 2019
0answers
Error Code 132
Be the first to answer 3/10/2014 3:24:03 AM • GE Monogram... • Posted on Mar 10, 2014Be the first to answer
manual
The dis play is showing
remove the electric cook top from wall, wait for about an hour, then pug it back in. If it still displays "Wait", then be patient because it seems its loading.
If it doesn't come out of wait after a while, then it means there is a fault.
Please let me know so that I may direct you further.
Bye for now.
2/2/2011 5:47:23 PM • GE Monogram... • Answered on Feb 02, 2011
Burned out high wattage switch for GE monogram
hi,
www.searspartsdirect.com
jm
1/6/2011 4:39:29 AM • GE Monogram... • Answered on Jan 06, 2011
Need to clean contacts on control knobs under
Sorry to read about your problem, I hope this helps you out.
their is no cleaning of contacts, they are sealed units..have to replace the switch,
you have to remove the entire range from the counter top..will take 2 people
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
12/21/2010 4:31:50 PM • GE Monogram... • Answered on Dec 21, 2010
The stove keeps clicking and
The light what we call sparking is produced by a MODULE SPARK Part Number: AP3993727 made by GE, item no 318, This module by turning any of your Knobs item no 29 it produce the sparking by a switch which is connecting the wiring of the VALVE GAS Part Number: AP3994025 made by GE, item no 314 to the above MODULE SPARK.
So either the switch attached to the GAS VALVE is stuck on (sometimes this happen after some water spillage over the knob, or just by long time use. In this case you have to remove the two wires on the valve you have the e sparking always on if the sparking goes OFF then replace this valve switch. If you still have the sparking then you need a new SPARK MODULE.
You can reach all parts mention above by removing all burners complete, bases, heads, lids and then lift up the MAINTOP.
Here below we have the link with all above mention parts and all the part layout of your stove which will help you find the parts mention and even order them if you like.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5203210&diagram_id=25791125
10/27/2010 6:05:38 PM • GE Monogram... • Answered on Oct 27, 2010
Sparking which causes circuit breaker
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
Circuit Breaker Keeps Tripping
heatman101
10/3/2010 2:35:13 AM • GE Monogram... • Answered on Oct 03, 2010
2answers
Hi...I am getting a burnt
When you smell rubber burning it means the belt is slipping. Usually this happens because the roller is seizing up. Pull the roller out (normally you can do this by removing a few screws) and check to see if hair or carpet strands are clogging it up. If it seems clear replace the roller and belt.
Let me know, if needed further assistance.
Hope i helped you,
Thanks for using ' Fixya ' and have a nice day!!
1/22/2010 6:23:24 PM • GE Monogram... • Answered on Jan 22, 2010
GE ZEU36 leds turning on in cascading effect repeatedly when power plant on
50Hz or 60Hz alternator?
circuit board on the stove may be frequency locked
10/30/2008 9:03:52 PM • GE Monogram... • Answered on Oct 30, 2008
'what is the amperage rating for model zeu36rbf2bb'
30-40 amps should do it
2/14/2008 11:38:43 PM • GE Monogram... • Answered on Feb 14, 2008
Replacing Grill module with gas burner on GE Gas cooktop (PGP990)
You can't modify gas appliances.
9/27/2023 5:42:09 PM • GE Cooktops • Answered on Sep 27, 2023
Wiring for GE Cooktop 1960s
I have an early 1970s GE, and we keep saying when it breaks down, we will replace it, but apart from replacing elements, it just goes on and on. Unfortunately, neither of your numbers give results. There should be a plate near the power lead that has the details and some have a parts manual and wiring diagram in the rear of the console if it has one. https://www.google.com/search?q=GE+82212+cooktop https://www.google.com/search?q=GE+YT123887L+cooktop ..
9/17/2023 10:38:35 PM • GE Cooktops • Answered on Sep 17, 2023
2answers
Fuse location on GE Profile PP975S Cooktop (If there is one)?
Question edited for clarity. There is no fuse, the loads are too great. The Service Manual is in the link. Check the Control Lock on Page 11. https://ja.safe-manuals.com/source/pdf/adea1af72b5b020af66562d603ff2631 https://www.google.com/search?q=ge+pp975s+fuse+location ....
12/25/2022 7:57:23 AM • GE Cooktops • Answered on Dec 25, 2022
How do you remove only the maintop cover of a GE JGP963 gas cooktop? I need to replace a part, but can't remove the maintop even after unscrewing and removing every burner.
It is a gas appliance. From the installation manual. Installation and service must be performed by a qualified installer, service agency or the gas supplier. It needs to come out as there is almost certainly fixings from below. Screws on the burners, only hold the burner rings down. The installation manual doesn't say how the top comes off, just how to install. No Service Manual for it. https://www.manualslib.com/manual/57348/Ge-Jgp630.html?page=1#manual ..
12/1/2022 8:15:10 PM • GE Cooktops • Answered on Dec 01, 2022
F152 error GE Monogram electric cooktop
Take out the right front burner and use your multimeter to check it for continuity. Only then can you be sure that the error code isn't lying to you. It is my guess, that with an error message so specific, that if no burners are working, it is not the front right burner at all. Hands on testing is the only way to be sure. F152 means the right front burner has failed, the sensor in it is bad, the burner will need to be replaced.
error code F152 ' Appliance Video
The element is $225.00 so it is not something to change on a guess. Full testing procedure here, or call for a Service Engineer. https://www.appliancepartspros.com/answers-for-ge-element-radiant-lt-wb30t10080-ap3188020-question-148609.html ..
3/20/2022 6:27:28 PM • GE Cooktops • Answered on Mar 20, 2022
GE Monogram ZEU36 Electric Cooktop Logo
22 questions posted
Top GE Cooktops Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a GE Cooktop Expert? Answer questions, earn points and help others
View Most Popular
GE Cooktops
  • GE Cooktops
Most Popular Question
amperage rating model zeu36rbf2bb
  • Cooktops
