I have a new Acer Veriton M460 Core2 Quad PC running Vista Business. Something weird is happening that seem to be related to the Vista Task Scheduler.
I have a complex chain of actions that start from one action. The chain is: run software to download .html files, run Microsoft software, run DOS batch files and DOS executables.
It works fine if I start it from the desktop and if I start it using Task Scheduler.
However, if I used Task Scheduler, the next time I boot up the PC it freezes at the Acer pre-Windows boot screen. Even the set up keys mentioned on that screen don't work, e.g. "press F12 to choose a start up mode". I have to pull out the power plug.
When I plug the power back in, even after quite some time, the PC proceeds with the boot up successfully through to Windows without me having pressed the Power On button on the computer.
So the bottom line is that if I use the Scheduler, my PC won't start the next time I go to use it.
There was an event that may have some relevance or could be coincidence: about a week ago after I first scheduled the task I came back to my PC, which had run my scheduled task unattended after waking itself from Sleep Mode. I found it showing not Windows but the PC boot options menu. I pressed the highlighted option, which I think was Normal. This hasn't happened since but could be related.
Incidentally, my PC was supplied with Sleep Mode set to start after 20 minutes plus there is a screen saver. But neither was going when I last used the scheduler for my task.
Any ideas?
SOURCE: Acer Aspire T180-UB72 does not boot
I have the same model and had the same problem. Fortunately there is a simple fix - unplug all your USB devices (mouses, printers etc). It should now boot!
Assuming that fixed it, it was trying to boot from a USB drive for some unknown reason. I think it was due to the latest windows XP update. Wierd. Hit F12 next time you reboot and make sure it is booting from hard disk first.
SOURCE: My ACer T180 does not boot boot up
sound like the hard drive. do you hear the drive spinning?? you may need replace or reformat.
what OS are you running....?
SOURCE: ACER T180 does not boot up
When I turn on my computer it shows a black screen and says my booot mgr is missing. what does that mean and how do I fix it?
SOURCE: windows xp will not load on my computer....
When you boot the machine in safe mode, it lists a whole load of drivers its loading. What is the last file it gets to before it reboots?
DONT US THE SCHEDULER!
