Replacement cover for FP 1450 FOOD PROCESSOR
SOURCE: Need User Manual for Black
Download the PDF file version directly from Black and Decker at
www.blackanddeckerappliances.com/dyn/prod/user-guide/69/FP1435%20FP1445.pdf
SOURCE: assembly directions for food processor
I had same problem and found answer on another website:
Front on machine is the one with the label on it.
One thing: the instructions aren't particularly clear on assembly. The bowl handle should be *toward* you when you lock it on the base, pointing toward you when you stand facing the label side with motor to right and bowl to your left. Then the lid just slides right on and when you turn counterclockwise a quarter of a turn it locks into place with no effort as the key slides into the slot and locks. I had this idea the handle should be on the backside of the machine, and it will fit on that way, but then you can't get the lid to fit securely.
SOURCE: need operating instructions for black & decker
hi u can download the manual from any of the following links....
http://kitchen.manualsonline.com/manuals/mfg/black_decker/fp1435.html
http://www.everythingkitchens.com/black_and_decker_quick_n_easy_food_processor_FP1435.html
http://kitchen.manualsonline.com/manuals/mfg/black_decker/fp1300_series_fp1400_series.html
kindly rate my service...
have a nice day
SOURCE: Need to find a replacement blade for B&D
call 1-866-925-PART
the two parts you will need are
175728-00 disc stem assembly
175726-00 blade assembly
2.95 for the disc
9.95 for the blade
SOURCE: I need a Disc Stem for my Quick 'N Easy Food
call 1-866-925-PART
ask for part number
175728-00
3.00 bucks
