Question about Black & Decker FP1400 Quick N Easy Plus Food Processor
Assembly directions for food processor
Manual does not tell you how to assemble the black and decker quick n easy plus food processor
Posted by glencovefarm on
  • ca79girl Apr 07, 2009
    It's true. It does not give detailed instructions! I need help
Anonymous
I had same problem and found answer on another website:
Front on machine is the one with the label on it.
One thing: the instructions aren't particularly clear on assembly. The bowl handle should be *toward* you when you lock it on the base, pointing toward you when you stand facing the label side with motor to right and bowl to your left. Then the lid just slides right on and when you turn counterclockwise a quarter of a turn it locks into place with no effort as the key slides into the slot and locks. I had this idea the handle should be on the backside of the machine, and it will fit on that way, but then you can't get the lid to fit securely.
Posted on May 26, 2009
My blade broke on my Food processor Model CFP10
Available replacement parts for your Black & Decker FP1400 Quick N Easy Plus 8 Cups Food Processor can be found here:
http://www.directpartsandproducts.com/food-processors-fp1400-c-1_378_406.html
Jan 21, 2011 | Black & Decker FP1400 Quick N Easy Plus...
Need to find a replacement blade for B&D
call 1-866-925-PART
the two parts you will need are
175728-00 disc stem assembly
175726-00 blade assembly
2.95 for the disc
9.95 for the blade
Aug 05, 2009 | Black & Decker FP1300 Quick N Easy Food...
Need User Manual for Black & Decker Quick 'N Easy Plus® Food Processor.
Download the PDF file version directly from Black and Decker at
www.blackanddeckerappliances.com/dyn/prod/user-guide/69/FP1435%20FP1445.pdf
Apr 28, 2008 | Black & Decker FP1445 Food Processor
Black & Decker FP1400 Quick N Easy Plus Food Processor Logo
1,017 people viewed this question
Top Black & Decker Food Processors Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a Black & Decker Food Processor Expert? Answer questions, earn points and help others
