Konica Minolta Dimage Scan Elite 5400 II Film Scanner Logo
A
Anonymous Posted on Dec 14, 2012
Dimage scan elite 5400 II driver for MacOS 10.7 and above
The Mac driver for Dimage scan elite 5400 II film scanner will work only through MacOS 10.6; does anyone know where to obtain a driver for MacOS 10.7 and higher (Lion, Mountain Lion)?
1 Related Answer
A
Anonymous
  • Posted on Jan 31, 2008
SOURCE: MINOLTA SCANNER DiMAGE SCAN ELITE 5400 II
My 5400 2 scanner worked well with windows XP but will not start with my new computer WINDOWS VISTA.
ERROR message Can not find scanner, check connection
ERROR message 1 unknown error
The scanner was purchased new 1-2006
my installation dick is for Win. XP Version 1.0.1.
Can not use DiMAGE 5400 on windows XP
I have the same problem. It works fine in xp
I am running Windows 7 and want to use my minolta Dimage scan elite 5400. my laptop cannot locate drivers and i have no installation disk. minolta does not have the driver listed on their site. how can i...
try this solution posted here 2 years ago originally and updated about a month ago. The solution is provided by KainAnderson
http://www.fixya.com/support/t872019-minolta_dimage_scan_elite_5400_vista
alternatively, there's something called vuescan that should be compatible, but it costs $39.95
http://www.hamrick.com/
5helpful
Does Kainanderson's solution work with Win7 64bit
Of course it does. I'm using both a Minolta Dimage IV and Minolta Dimage Elite 5400 Mk 1 (firewire and usb). Here's my latest driver:
; sonyscanners.inf -- Sony (Konica Minolta) Film Drivers
; Beta driver for Windows Vista and Windows 7 operating
; systems for all known Sony film scanners.
[Version]
Signature="$CHICAGO$"
Class=Image
ClassGUID={6bdd1fc6-810f-11d0-bec7-08002be2092f}
Provider=%Provider%
DriverVer=2/19/2011,3.0
[Manufacturer]
%Mfg%=Models,ntamd64
[Models]
; USB and SCSI scanners
"Minolta Scan Dual II" = USBScanner,USB\Vid_0638&Pid_026a
"Minolta Scan Dual III" = USBScanner,USB\Vid_0686&Pid_400d
"Minolta Scan Dual IV" = USBScanner,USB\Vid_132b&Pid_000a
"Minolta Scan Elite 5400 2" = USBScanner,USB\Vid_132b&Pid_0012
"Minolta Scan Elite 5400" = USBScanner,USB\Vid_0686&Pid_400e
"Minolta Scan Elite II" = USBScanner,USB\Vid_0686&Pid_4004
"Minolta SC-110" = USBScanner,USB\Vid_0638&Pid_0a15
"Minolta SC-215" = USBScanner,USB\Vid_0638&Pid_0a16
"Minolta QuickScan 35" = SCSIScanner,SCSI\ScannerMINOLTA_#2880___________
"Minolta Scan Dual" = SCSIScanner,SCSI\ScannerMINOLTA_#2882___________
"Minolta Scan Multi" = SCSIScanner,SCSI\ScannerMINOLTA_#2883___________
"Minolta Scan Speed" = SCSIScanner,SCSI\ScannerMINOLTA_#2884___________
"Minolta Scan Elite" = SCSIScanner,SCSI\ScannerMINOLTA_#2885___________
"Minolta Scan Elite 5400 Firewire" = SBP2Scanner,SBP2\MINOLTA&DS_Elite5400&CmdSetId104d8
[Models.ntamd64]
[USBScanner]
Include=sti.inf
Needs=STI.USBSection
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
[USBScanner.Services]
Include=sti.inf
Needs=STI.USBSection.Services
[SCSIScanner]
Include=sti.inf
Needs=STI.SCSISection
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
[SCSIScanner.Services]
Include=sti.inf
Needs=STI.SCSISection.Services
[SBP2Scanner]
Include=sti.inf
Needs=STI.SBP2Section
SubClass=StillImage
DeviceType=1
DeviceSubType=2
Capabilities=0
[SBP2Scanner.Services]
Include=sti.inf
Needs=STI.SBP2Section.Services
[Strings]
Provider="Sony (Konica Minolta)"
Mfg="Sony (Konica Minolta)"
1helpful
Why won't Minolta film Scanner work with iMac and OSX 10.6.2?
Hi
I bought a secondhand, nearly new Minolta Dimage Scan Elite 5400 a few years ago but never tried to use it until now when I tried to get it to work with my iMac running OSX 10.6.2. I uploaded the Dimage software but I cannot get it to recognise the scanner - any suggestions? Do I need to get updated drivers?
79helpful
10answers
Minolta Dimage Scan Elite 5400 - Vista driver?
1) Install all of the usual Minolta software in Vista if you haven't already.
2) Create a new folder somewhere
3) Create a new txt file in that folder and name it minolta.inf and paste this into it:
; minolta.inf -- Test Vista Minolta Film Drivers
; To remove this driver and install the original
; manufacturer's driver, go into Device Manager,
; open Imaging devices, then click on the scanner name
; with the right mouse button and choose Uninstall.
[Version]
Class=Image
Provider=%Provider%
DriverVer=3/12/2009,2.0
[Manufacturer]
[Models]
; USB scanners
;---------------- Duplicated from [Models]
[Models.ntamd64]
; USB scanners
;---------------- USBScanner -------------------------
[USBScanner]
Include=sti.inf
SubClass=StillImage
DeviceType=1
DeviceSubType=1
Capabilities=0
Include=sti.inf
[Strings]
Provider="Konica Minolta"
Mfg="Konica Minolta"
4. Save file. Turn on scanner and go into device manager and update the old minolta driver with this driver. You may have to manually update it.
5. Once installed, all the normal Minolta programs now work just fine. Enjoy!
I tested this on Vista 32 Ultimate with a Dimage IV but it should work on all the models listed in the .inf file.
2answers
Dimage Scan Elite Windows XP installation problem
you've probably long since fixed this, but when this happened to me, i needed to unplug the scanner entirely from the computer, deinstall the driver, reinstall the driver, then plug in the scanner, let it be detected, and then it worked. another time when this happened and the above didn't work, i had to delete a usb root something-or-other, reboot yet again, let windows fix itself first, then do the scanner install all over again.
1helpful
Can't start up Konica Minolta Elite 5400 II
This problem usually occurs when the scanner software crashes, or the scanner is turned off in operation, or the computer is shut down before you quit the software, etc.
The K-M driver software gets corrupted.
I use mine with a Mac G3 Tower and OS-X v 10.4.9.  What I do is search for all the Konica-Minolta components using OS-X spotlight and then delete them.  After reinstalling the K-M driver software and restarting the mac, the scanner should work fine.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
