SOURCE: lens error, restart camara issue in SD900
well **** that doesnt sound complicated or anything.
SOURCE: canon rebel xsi gets message card write protected
hi, when i turn on my camera the screen says card write protected? and I can't take pictures on my canon xsi
SOURCE: Memory card locked
Hello
Ok, here is something you can try:
In your case the problem is not with the card but rather with your
camera's card reader. This is a rather hard problem to fix yourself but
here is what you can do.
Open the card slot of your camera and
peer inside with a sharp light or torch. You should see a little metal
tab or switch inside the card slot. This is the write protection
switch. Contrary to popular belief , the switch on the card does not
impact the operation of the card itself but rather tells the camera
that the card should be locked by depressing the little pin inside.
If you put a protected card into a camera with no protection switch , the card would operate normally.
However
, with time and repeated use , the switch will start to bend slightly
until it will no longer depress when a unlocked card is inserted.
With
a toothpick or needle , slightly and very gently push this tab up a
little bit. (some camera's will require you to pull the tab down), This
will allow the switch to operate once again and should solve your
problem.
Kind Regards
Andrea
Testimonial: "Yes it works. I realy thank you and StephanSA. Now is the camera ok. Quick, perfect destripted and felpful answer. "
SOURCE: camera is stating No Card when there is an SD card in camera
camera sd card board is faulty you need to relace new sd card board.
