20 Most Recent Canon EOS 1100D Rebel T3 Body Only Digital Camera Questions & Answers
3answers
The memory card says card cannot create folder
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.After unprotecting the card, insert it into the camera and format it.
7/22/2019 8:57:31 AM • Canon EOS 1100D... • Answered on Jul 22, 2019
Canon eos t3 error 30
Error Code 30 indicates that a Malfunction related to the shutter has been detected.
9/2/2016 10:09:23 PM • Canon EOS 1100D... • Answered on Sep 02, 2016
My camera says "Cards write protect switch is set to lock" what should i do to unlock
There is a very small lock switch on the SD card make sure it is not on lock.
9/2/2016 9:59:02 PM • Canon EOS 1100D... • Answered on Sep 02, 2016
How do i transfer my photos from moto x phone to laptop?
It depends on what software your are using. If you're using the software that came with the camera connect your camera to the computer with the USB cable that came with the camera and use the EOS Utility program.
9/2/2016 9:42:40 PM • Canon EOS 1100D... • Answered on Sep 02, 2016
How to fix err,30 on canon t3
Have a look here for error code 30 http://www.canon.co.uk/support/consumer_products/product_ranges/cameras/eos/error_codes/
8/29/2015 8:21:08 PM • Canon EOS 1100D... • Answered on Aug 29, 2015
How to transfer photos on may casio camera to my loptop
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa. Organize edit and share your photos
11/21/2014 4:05:30 PM • Canon EOS 1100D... • Answered on Nov 21, 2014
My camera's built in flash is not working and is making crackling sounds ....how do I fix it?
  • the mechanism is jammed i have experienced this before try by gently pull the camera flash (assist the motor to release the flash) once you press the flash button
8/23/2014 3:40:43 AM • Canon EOS 1100D... • Answered on Aug 23, 2014
My camera's built in flash is not working and is making crackling sounds..... how do I fix it ?
When you say "crackling sounds" do you mean electrical sounding crackles or something like gears grinding? If it's the first and especially if you smell something electrical then immediately send it back to Canon for repairs. If there's a short in the wiring or capacitor it could melt or worse. If it's more of a mechanical sound it may be debris lodged in the release mechanisim.
8/14/2014 12:16:56 PM • Canon EOS 1100D... • Answered on Aug 14, 2014
Is the locked position up or down on a sd card
6/30/2014 2:01:17 PM • Canon EOS 1100D... • Answered on Jun 30, 2014
How do i reset to default settings for canon eos rebel T3
Remove the battery for 15 mins then insert the battery and go to the memu and set the Date and Time etc.
5/16/2014 7:14:35 PM • Canon EOS 1100D... • Answered on May 16, 2014
How to impose date and time stamp on sony cyer-shot camera
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
5/11/2014 8:37:48 PM • Canon EOS 1100D... • Answered on May 11, 2014
Memory Card slot broken?
It sounds like the spring-loaded catch that holds the SD card in is missing, broken, or the spring is too weak. If it's reading the card by just closing the battery door, then the card is making a circuit with the camera's internal contacts, but that is far from ideal, and I would not be surprised if that method caused additional damage in the long run. I recommend you bring it to a reputable camera shop, and see what the cost would be for the repair. I suspect it would be a LOT cheaper than breaking the camera or an internal circuit board by trying to kludge a solution. The parts are probably a few bucks, it's the labor cost that you would end up paying for, but better that than breaking the device.
5/6/2014 9:37:04 PM • Canon EOS 1100D... • Answered on May 06, 2014
In my Canon 1000D the flash does not pop up when i
Did you do a factory reset,try it first.
10/16/2013 1:04:02 PM • Canon EOS 1100D... • Answered on Oct 16, 2013
How to zoom x5 o x10 with canon 1100D and then
That depends on the lens you have mounted on the camera. In general, you turn the zoom ring on the lens to the desired position.
8/10/2013 8:19:04 PM • Canon EOS 1100D... • Answered on Aug 10, 2013
Canon camera would not take photos outside at night and ok indoord
Something wrong with the setting.find the menu to reset all the settingAnd read http://www.wikihow.com/Take-Good-Photos-Using-a-DSLR
1/24/2013 8:44:14 AM • Canon EOS 1100D... • Answered on Jan 24, 2013
Is there a way to retrieve photos taken on a canon eos rebel t3 when no memory card was inserted?
I'm afraid not. The camera does not have any memory to store photos. You can take one photo and look at it on the screen to see how the camera works, but this is primarily for demonstration purposes. Shooting without a memory card is like shooting an old film camera without any film loaded. You can go through the motions of taking a picture, but nothing is stored permanently.
12/1/2012 3:42:46 PM • Canon EOS 1100D... • Answered on Dec 01, 2012
Canon EOS 1100D Rebel T3 Body Only Digital Camera Logo
48 questions posted
Top Canon Cameras Experts
old marine
old marine
David Shaub
shadow
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
Eos Canon
  • Eos Canon
Most Popular Question
  • Cameras
