Check its main power supply regulator section for the fault. Check the fuse. If the fuse found open or burned, find out the reason first. If so, there must be some kind of short circuit inside the circuit board. Might be some components to get shorted. Check it first. Rectify the reason for the fault first, and only then replace the fuse, if it is found faulty.
Visit the site named 'Electro-help' for more
details. Click this link. View it in
"Timeslide" or "Flipcard" option, which can be selected
from the drop down box menu by the [Sidebar] tag, at the top left corner
of the display window. It will make
search easy. There are more than 1300 posts to different brand TVs now. Pull up
older posts there. Sometimes it might help you.
