SOURCE: Hampton Bay Ceiling Fan - Clarington 503837 52"
It slides in above right above the ball, in the mounting bracket where the canopy is. You may have to kind of encourage it to go in there, and you will need to push wiring off to the sides and out of the way to help it have clearance to get in there.
SOURCE: Remote receiver doesn't fit
ok since you have the power off move ceiling fan box electrical box over place remote above the electrical box with the antenna sticking out replace fan power up you might have to go into attic to place the remote sensor and antenna down to outside of fan i had the same problem myself i made a cut in drywall ceiling big enough for sensor unit let the antenna hang out placed up there
i used a wall plate cut in half to match the hole i just made or you dry wall back up but if remote goes out theres now no way to get to sensor unit
little cut in drywall place sensor threw antenna hang down put plate over hole
SOURCE: Mounting a Hampton Fan Model 52-CL
hello d,
1. yes, with the proper rod, longer wires(3,4) and the blades must be over 2.5 metres (8 foot) above the floor.2. you need the proper type box; the mount/s and ball; the longer wires (3,4)with slender but connertors; and especially the safety pins, etc. with the proper rod, the fan will hang straight. and about 3 chock hours to do this here task. hope this helps.
