Keyfob remote reprogramming is not very difficult but on some cases it can be done by dealer service tools.If the remote s faulty then keyfob will not get programmed.Insert the key in ignition.Turn the key to on position,and cycle the key three times off-on-off-on-off-on.Then with the keyfob remote select your remote and then try to operate the vehicle with remote.These is just the basic procedure,but sometimes it will not help. http://technoanswers.blogspot.com/2011/12/audi-a8-key-fob-programming.html ---------------- http://technoanswers.blogspot.com/2011/12/olds-aurora-key-fob-reprogramming.html ------------- http://technoanswers.blogspot.com/2011/12/buick-lesabre-key-fob-reprogramming.html --------------- http://technoanswers.blogspot.in/2012/01/keyfob-remote-not-working-on-2003-ford.html ----------- http://technoanswers.blogspot.in/2012/02/key-will-open-doors-but-not-start-on.html ------------ http://technoanswers.blogspot.in/2012/02/key-fob-will-not-lock-and-unlock-doors.html ------------- http://technoanswers.blogspot.in/2012/02/theft-indicator-not-letting-car-to.html -------------
On that case dealer is the only option.
---------There are few very relted troubleshooting links mentioned below for remote key fob reprogramming.I suggest you to go through the list and click the link below to go through its details and procedure:-------
2009 Toyota Highlander: Smart Key Not getting
Detected?
http://whatisbyme.blogspot.in/2012/05/2009-toyota-highlander-smart-key-not.html
----------2007 Toyota Prius: Reprogram Remote Keyfob?
http://whatisbyme.blogspot.in/2012/05/2007-toyota-prius-reprogram-remote.html
Pin
that holds the flick key part to the key fob?
http://whoisbyme.blogspot.in/2012/07/pin-that-holds-flick-key-part-to-key-fob.html
2006 Toyota Hilux: Programming New Key?
http://technoanswers.blogspot.in/2012/04/2006-toyota-hilux-programming-new-key.html
----------Where is Key chip memory located on 2004 ford Freestar?
http://technoanswers.blogspot.com/2012/01/where-is-key-chip-memory-located-on.html
----------Ford Keyless Remote Fob Reprogramming?
http://schematicsdiagram.blogspot.com/2011/12/ford-keyless-remote-fob-reprogramming.html
----------After getting car
washed, check engine light is ON and key less entry not working, tried
reprogramming. Also car shows fuel pressure?
http://schematicsdiagram.blogspot.com/2011/12/after-getting-car-washedcheck-engine.html
-----------Audi A8 Key Fob Programming?
Oldsmobile Aurora Key Fob Reprogramming?
Buick Lesabre Key Fob Reprogramming?
Keyfob remote not working on 2003 Ford E350 Econoline?
KeyFob will open the doors but not start on BMW?
Mitsubishi Car Key Not getting detected after replacing ECM
http://repairhelpcenter.blogspot.com/2012/11/mitsubishi-car-key-not-getting-detected.html
Key Fob will not lock and unlock doors?
2000 Jeep Cherokee Limited: KeyFob Remote Not
Working?
http://schematicsdiagram.blogspot.in/2012/06/2000-jeep-cherokee-limited-keyfob.html
Chevrolet Malibu: Key Stuck in ON position?
http://technoanswers.blogspot.in/2012/04/chevrolet-malibukey-stuck-in-on.html
Theft indicator not letting car to start?
2012 Dodge Ram: Ignition Key will not
release?
http://whoisbyme.blogspot.in/2012/07/2012-dodge-ram-ignition-key-will-not.html
These details will help.Thanks.
There are two types of key fobs for a 2006 Tacoma. If you have this style you can program it yourself
To program this style remote follow these instructions:
Most remotes can be self-programmed. If this procedure does not work, you must have your remote programmed by a professional automotive locksmith or dealership.
Obtain all remote transmitters for this vehicle.
1. Insert key into ignition and turn ignition switch to ON position.
2. Locate the ECU (Engine Control Unit) and press and hold the ECU PROGRAMMING button for 3 seconds. The ECU will be located under one of the front two seats, the trunk, or under the dashboard on the drivers side. You will need a small pointy object like a pen to depress the ECU button. After pressing the ECU button for three seconds, you will see the STATUS MONITOR LED turn on for 5 seconds. Vehicle is now in programming mode.
3. Press and release the top button on the remote. The STATUS MONITOR LED will turn off. A chirp will be heard as well as one flash of the exterior lights.
4. Turn off the ignition. Programming is now complete, test remotes for proper programming.
Http://theandrewhughes.com/2007/05/how-to-program-most-gm-key-fobs/
