Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing. Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve. Step 2: Plug the washer back in and press [Power] to turn on the washer. Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected. Step 4: Press [Start/Pause] to begin a drain only cycle. Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
OVER SUDDSING
Hi
The 'LE' error message indicates the control
board has detected that the motor is either not turning, or has locked up for
some reason. Monitoring the motor is the job of the hall effect sensor board
which constantly determines the direction and speed of the motor and feeds that
information back to the control board. If there is a problem between what the
motor should be doing and what the hall effect sensor says the motor is doing,
the 'LE' will be displayed and the cycle will be stopped.
This error can sometimes present because of a miscommunication between
the control panel and the wash motor. In this instance, the washer simply needs
to be reset.
Please get back to us if you have further
query or else please accept the solution.
Thanks for contacting fixya.com
Hi
This error can sometimes present because of a miscommunication between the
control panel and the wash motor. In this instance, the washer simply needs to
be reset.
code is cleared.
sorry my problem for dish mashing
