Cant find any volume button on monitor its a new one and deoant even have a socket to put volume plug into any help would be gratefully appreciated
SOURCE: I have a problem with the HP w2408h Monitor, Volume is low, help!
Use the 'Sounds' option in control panel.
SOURCE: how i can to open the cover of lcd hp L1706
1.- remove 14 screw on back
2.- remove front cover con un desarmador plano pequeño, como si pucharas hacia afuera y luego al frente por toda la orilla.
3.- quitar la base es solo con un simple apreton y click y listo, sale la parte de abajo y luego aprietas la parte de arriba y estiras. y ahi vas a ver unas tuercas te puedes ayudar con una llave española o perica pequeña.
y listo.
SOURCE: how to check the backlight life of my hp l1706
Claimed life for the lamp is 50,000 Hours, but in real life, no way to tell. You can look here what is failed in the backlight lamps, it can be from worn out (blacken ends is one sign of bad lamps, same as home fluorescent lamp), poor soldering works on the lamps. see pictures here: http://s807.photobucket.com/home/budm/allalbums
What is the problem with your monitor anyway?
SOURCE: HP L1706 monitor - will not power on - green light
I had the same problem and replaced 2 bulged capacitors, screen is working fine again! (1000µF 10V)
SOURCE: el monitor hp L1706 no enciende, solamente la luz
Amigo tengo el mismo problema... ya lograste solucionarlo?? si es asi dime como porfavor gracias!
