I resorted factory setting and it has done nothing, i just recently got this computer from where i work, im thinking maybe its damaged? what should i do to sort this problem?
SOURCE: Screen So Bright I Can Barely See Anything...
The auto dimming circuit on the ccfl inverter is out. Replace the inverter and it should cure your problem. Seek adult supervision for this repair. Do not try it by yourself.
srich
SOURCE: Hp w2207h computer monitor problems
You will probably have to repackage and resend the monitor back for repair. sounds like a manufacturing mistake or bug.
SOURCE: lcd monitor will turn on for about 2 seconds then go blank.
butterx99, First thing you should do is surf the net for pics of swollen electrolytic filter capacitors. You will find many, many examples. You will also need to inspect both the switch-mode-power-supply and the inverter boards for failed thermally cracked (fractured) solder joints. I will try to attach a pic of what you would be looking for. You hav failed to mention how many printed circuit boards are in your monitor. Some have only 2, others have 3. If only 2, then the "inverter circuit is part of the SMPS board. Did you take pics so that you can remember where everything goes when you need to reassemble? Let me know by email if you don't get a the pic through fixya. Bye for now. I'm louie12fix on fixya or [email protected]
SOURCE: My HP LCD comes on when I turn on the power,but for few seconds.
The monitor has blown a capacitor, and if your good with a soldering gun and can locate the cap which will have the top rounded instead of flat, remove it and take it to the electronic store and they will give you a replacement. If the capacitor is bad it won't hold the charge and that's why you only see a second or two on the screen. Make sure you are capable of this kind of work, before you decide to do it.
