Can i get the scematic for a light outlet in Malaysia
Plugs in Malaysia are type G and match those from Great Britain: The ground slot pointing vertical, and both 230Volt power slots horizontal.
Copy following link for wiring illustration
http://waterheatertimer.org/How-to-wire-240-volt-outlets.html#type-G
Plugs in US are 120Volt. Plugs elsewhere in world are 230-240Volt
Be advised:
US produces 60 Hz electricity so generator rotates 60 times per second.
Malaysia has 50 Hz, same as Britian.
Unless your electrical device is rated for both 50/60 cycles, then a device from US market will not work in Malaysia.
Look at rating label on each device for cycles.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
