Moved two weeks ago and replaced copper water line to fridge with a soft plastic line (needed longer line). Water slowly fills @ 1/2" in cup & trickles to nothing. I thought may have been clogged filter from move (never replaced). However, NO filter in inside top, nor bottom front of fridge, per Appliance repairperson. Where is it or is there a filter to a 9 year old GE model ?????
SOURCE: Water won't flow from GE Smart Water under-sink RO water filter
Disconnect the water pressure tank making sure the end the line hooks up to is open. The tank should be relatively light, and if you shake it you should not hear any water. If you hear water in it, or it feels heavy, that means the bladder inside the tank has failed. Replace the tank with a new one, and set the pressure on the bicycle type valve at 8 PSI before you connect the tank up to the water line.
SOURCE: I replaced the water filter for my GE GSH25JSTA SS
I have had the same problem with the same model several times in the past. It also happens to me within a few days of replacing the water filter.
In my case, I believe the water line in the freezer door has become frozen. I usually let the freezer thaw for a couple of hours, and my water works again.
I have had constant problems with this model. I would recommend trying to sell your fridge now while it's still running, before the real headaches begin (mine has died 2x in the past six months, and I have not even had it for 2.5 years yet). No more GE's in my house.
SOURCE: burnt plastic smell coming from bottom of frig
This is a sign of a short and should be looked at immediately. A smell like that is a sign of something burning. I could be the start relay and start capacitor with overload. But I would not sleep with the possibility of a fire. I will look over your model and see if I can find what this could be, Sea Breeze
SOURCE: GE Profile leaking onto floor
Clean the drain pan and drain line in the back of the freezer section behind the cover underneath the evaporator coil. (hint: use turkey baster with hot water)
Make sure water drains when you
pour it in. If it doesn't - also clean drain tube on the back of the
unit behind the cover. When done - put the tube exactly where it was.
Good luck! :)
Vlad
First
Choice Appliance
SOURCE: GE Profile side by side fridge - water dispenser doesn't work
I disconnected the water line at the base of the door and forced air through the tube to the water despencer and reconnected it. Works fine now....
