Bypassed thermal fuse and seemed to heat, could see flame. Replaced fuse put everything back together and still not heating.
SOURCE: Gas Dryer quit heating today
Just click below;
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Hope it may help you;
Regards;
VOTIT
SOURCE: Whirpool gas dryer not heating up
Take a volt meter and call for the unit to come on. Take the connector off to the igniter and check for voltage to those wires. If you get voltage but it does not start, then you know the igniter is bad. It could also be a limit switch. There will be 2 wires that terminate to a small disk with a button in the center. Depress the button firmly to reset it. It should be located near the burner. If it is the timer, you will need to locate and isolate the power wires leaving the timer and check voltage there. Hopefully this information is helpful.
SOURCE: location of thermal fuse on leq9858 l dryer whirlpool
if this is a top load?if so remove the back panel and you will see the dryer heater box to your right,the fuse is on the left side of box top,the high temp thermostat is on the bootm left and should be replaced also,before you do thatmif you have a meter remove the 2 wires from the heating element and check it on omns,no meter?remove the 2 screws pull the element off and look to see if the coil is broke anywhere,let me know how you do-mkie
SOURCE: why dosent my dryer get heat
Look at the gas valve coils to determine if they are faulty. If the igniter radiates but then shuts off before it ignites the gas, then the coils are probably bad. Replace the coils and your problem should be solved. Also, if you find the igniter working properly then the problem may be with the radiant heat sensor. The sensors are usually located close by the igniter so are easily visible. Hire a repairman to replace these faulty parts.
SOURCE: whirlpool leb6000pq1 not heating
Thermostat controls heat. There is also a
motor centrifulgal switch, in the element
circuit, that the motor closes to insure
the motor is turning. Try another heat
setting. There is more than one
thermostat. You may have blown the
'thermal fuse' too, which requires
replacement. The elecment has a contact in
the 'timer' circuit too.
It is possible that your element has
failed also.
Tripped high limit. Must clean the lint
filter and the exhaust vent tube and all
the way in to the dryer. Hot air exit is
restricted.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
