My olivetti copier, model D-copia 16w, is displaying error 'H4' when I turn it on. Please help!
SOURCE: xerox pro 215, error H4 please help
H4 is a fuser error....not getting up to temperature.
Press [C] (Clear), press [Image Quality], press [C] (Clear) again, press [Image Quality] again.
If this doesn't bring it back to operations then the fuser lamp needs to be replaced.
SOURCE: What does an error code H4-01 mean on a Sharp
Fuser Heater failure. The fuser is the part of your machine that heats up and "fuses" the toner onto the paper. It is located right near where the paper exits the copier. This error code means that the fusing unit is not heating up as it should. The most common failures in order of ocurance are thermal fuse, thermister and heater lamp. In any case you are going to need a service person to come out and diagnoe which part has failed, replace the part and reset the code for you. Should not be more than say $200 to repair.
Good Luck and Thank You for using Fixya.
WheatlandServices
SOURCE: I need a driver for
the drivers can be found on this website, it is the manufactures website just scroll down the tab that says drivers until you find your printer model.
http://www.olivetti.com/site/public/support.asp
If this helped please rate.
Thanks
Robert
