I cant get the big speakers in the barbie cadillac escalade to work
There is an extra wire under the hood with the battery but for the life of me I cannot find where it would plug in and if you can imagine theres not a thing about it in the manual.
Which tail light ? Does the stop light ,turn signal work ? Check fuse's LR PARK fuse 10amp or the RR PARK fuse 10amp located in the under hood fuse box .
First check the fuses, one on left side of steering wheel - the other on the left (drivers) side under the hood. Look at the inside of the lids to see what the fuses work on. If fuses are okay, check the ground wires.
check the resister under the dash below the glove box its a flat plug with about 6 wires also see how many wires going to it a burned so when you go to the dealer for the resister you can get the connectors
You will have to get into the hood manually to jump the battery and the use the key less entry. Use a long flathead screwdriver and pop the hood latch. To do this simply push the latch horizontally with the screwdriver and the hood will pop open. Jump the battery and you will be able to get into your vehicle. I would then address the reason your battery dies if not replace it.
Check your fuses...the fuse for the OBII is probaly blowed...Or see if the scanner works in another car, to make sure the internal battery on the scanner is good..
