Canon PowerShot SD1000 Digital Camera Logo
Lisa Witham Posted on Sep 04, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Battery wont charge - Canon PowerShot SD1000 Digital Camera
  • kakima Sep 04, 2012
    Just to be clear, you are taking the battery out of the camera and putting it into the charger, not simply connecting the camera to a USB port?
Anonymous
Level 3:
  • Canon Master 32,281 Answers
  • Posted on Sep 05, 2012
Anonymous
Canon Master
Level 3:
Answers
32281
Questions
Helped
7913564
Points
102259
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Why wont my battery charge
did you put battery acid in it?,take it back if it wont charge
Why my power windows,dome lights,dont work plus car wont start
ok a lot not said here trouble shooting time. does the battery have a full charge "no" put a charge on it. battery wont charge and still wont do a thing dead battery get another one. ok battery charged and all works undo the positive cable on battery, if it still runs "good" if not alternator is bad. hope this helps not much to go on
Why wont my one touch premier battery charge?
Try a different charger if still no charging then replace phone battery
1helpful
2answers
Built in battery wont hold its charge
Aug 21, 2012 • Cameras
Wont keep charge
sounds like your alternator then
if alternator is not working, it is not charging the battery whilst driving
2answers
My camera wont charge
have you check the charger? or is there a power on the outlet? try to charge it from different power source
Razor cell phone wont charge
steps... 1) check by using another charger...if it gets charged then change ur charger.. 2)if its not getting charge then replace the battery and then try charging...if its again not working then battery problem..change it 3)if the battery s in proper condition then the problem s with the phone charging socket..change it for cost!!!!!!!!
2answers
Laptop battery wont charge?
It could be the battery needs replacing ... it shows that the battery is charging but it doesn't keep the charge .....
Battery wont work
The battery is dead and it won't charge or hold its charge (all rechargeable batteries have a finite number of charge and discharge cycles). You need to buy a new battery, or just use the laptop connected to the mains supply.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
