First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
SOURCE: My iphone 3gs won't turn on. If i plug it into
Sounds like you have at least a broken battery. Apple should give you a replacement. If you're out warranty, you can try to open it and replace battery. If that fails you need a new logic board. You can get the part at iPad Repair and there is a guide that shows you how to open a kindle and install parts at iPad Repair Guide.
SOURCE: iPhone gets hot, wont turn on after that.
there is a hardware issue. Apple should give you a replacement. If you're out warranty, you can try to open it and replace the logic board. You can get the part at iPad Repair and there is a guide that shows you how to open a kindle and install parts at iPad Repair Guide.
SOURCE: Hi my iPhone 3GS is dead. I have tried everything
Sounds' like your battery is defective. Bring it to the apple store. If they want to charge you for a replacement phone, try to replace the battery yourself, part is on ebay and there is a guide that shows you how at : iPhone 3GS Repair Guide
