Question about Mitac Mio 168 Pocket PC
SOURCE: mitac mio 168 digiwalker
Hi, to replace battery, you need to undo the 4 screws hold the back casing. When these are removed you can open the back, revealing the battery. There is a black plug that pushes into a white socket on the pcb, with 4 wires coming out of it that goes to the battery. Pull this plug out and the battery then comes free. Hope this helps.
Posted on Jan 24, 2007
SOURCE: Mitac Mio 168 Digiwalker cannot recon SD card
your SD might be and SDHC or larger that 4GB. try to use a FAT32 formatted SD, no bigger than 4GB
Posted on Sep 04, 2009
Testimonial: "what if its bigger than 4GB?(i used an 8GB card actually)...i'll try and let you know...thanks"
SOURCE: no gps signal on my mio digiwalker 168
Please try and reset the unit , check for fault in the settings . You can also remove the power and try a long reset and if after the boot there is no detection it is best to seek assistance specially if the unit is new as you can avail of free replacement warranty.
Posted on Nov 07, 2011
Nov 06, 2011 | Mitac Mio 168 Pocket PC
Sep 04, 2009 | Mitac Mio 168 Pocket PC
Aug 07, 2009 | Mitac Mio C220 GPS Receiver
Dec 26, 2008 | Mitac Mio 168 Pocket PC
Mar 25, 2017 | Mitac Mio 168 Pocket PC
Sep 09, 2008 | Mitac Mio 168RS GPS Receiver
May 27, 2008 | Mitac Mio 168 Pocket PC
Mar 17, 2008 | Mitac Mio 168 Pocket PC
Aug 28, 2007 | Mitac Mio 168 Pocket PC
Jan 16, 2007 | Mitac Mio 168 Pocket PC
Feb 02, 2014 | Mitac Mio 168 Pocket PC
Nov 02, 2013 | Mitac Mio 168 Pocket PC
Jul 31, 2013 | Mitac Mio 168 Pocket PC
May 20, 2013 | Mitac Mio 168 Pocket PC
99 people viewed this question
