I have just replaced my battery in my Mio p560. On the back of the Mio at the top - remove the two small rubber bungs, you will see the screws underneath. On the back at the bottom you must remove the alluminium strip to get at the remaining two screws. This is the only tricky bit! The strip has the hole for the pointer on the right, with a small screwdriver prise up the LEFT side of the strip, it is stuck down but will come if you are gentle! Then you can detatch the strip at the right side. The two bottom screws will be under this strip. remove the four screws now. The FRONT of the Mio can then be separated from the back, it just clips along the sides. The battery can then be got at and exchanged. When you re-assemble make sure the on/off switch locates properly. Thats it! Regards David Harford
