SOURCE: JennAir JSD2789GES ice maker /water dispenser
Dave, this is a bad valve. Replace it and all will be well in the world again.
SOURCE: Ice Maker stopped making ice - water dispenser is fine.
I have had the same problem with different problems each time. The first time the stop lever came loose on one end. This resulted in the ice maker remaining in the off position but looked like iWhen I removed that it worked again. Hope this helps
SOURCE: Maytag MSD2754GR - Ice Maker quit working.
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in
it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let
it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then
try the water dispenser. The water should go to the ice maker. This will tell
you weather or not the ice maker valve is working and if the line is clear.
Testimonial: "Good trouble shooting tips...will give them a try and see how they go, THANKS!"
