My fridge is holding temp for now, but my freezer stopped working. I don't know how to fix it. I can't afford a new fridge. Are there reset buttons on this fridge/freezer?
Look inside the freezer for frost buildup on the rear wall. Let me know if there is frost building because that would indicate a defrost problem causing the warm up. Also check your model number because you are the only one on the internet with a model MSD2561HES for the USA Once you have the correct number and answer back about the frost buildup I will tell you each step to take solving this problem which I think is a defrost problem at this point, Thanks Sea Breeze I think your model has the adaptive defrost control board that may be at fault=> 4388932 Defrost Control Board
SOURCE: fridge not cool, freezer fridge temp
The most likely fault is a problem with the defrost cycle. The most likely is the defrost heater which should be a solid bar which is located directly underneath the coil. If you are capable then you can generally unplug the connectors for the heater and check that you have a resistance across the ends if the heater is faulty it will be open circuit. If it is not open circuit then it could be the defrost sensor or defrost timer at fault. You can also generally tell if the heater is warped or cracked. Hope this is of some help.
SOURCE: Maytag refrigerator Model MZD2766GEW
You need a new Adaptive Control - part number 61005988.
SOURCE: Maytag refrigerator cooling probelm
Defrost the fridge, take everything out of freezer and turn off for at least a day, check the drain is clear after defrosted and try again, if it happens again you may need a new defrost heater of timer.
SOURCE: fridge is warm even when i adjust temp. control.freezer is good.
if your fridge has 2 set of dials one numbers and the other letters than you need to adjust the dial that has letters on it. If the fan in your freezer is not blowing, then it won't force the cold air from the freezer to the fridge. Make sure fan blows then adjust the letter knob.
